Home > Maintenance & Modifications > Single piece Truck Cab Rear Glass
hank
I recently bought a spare truck cab window frame to investigate replacing the sliding glass with a fixed single solid piece of glass.
On inspection of the spare frame I can see that this is possible. Is anybody aware of a single solid piece of glass retailer?
If not I will investigate having one cut locally
Post #662613 8th Nov 2017 12:24pm
Easy job for a plant glass fitter Thumbs Up QRZ 2e0vpf
Post #662614 8th Nov 2017 12:27pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Vehicle Glazing Specialists sell a couple of different versions, not cheap mind you. https://www.vehicleglazingspecialists.com/...h=63_59_60 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #662615 8th Nov 2017 12:37pm
hank
I want to retain the aluminium frame and fit a one piece pane into the slider recess. The VGS ones use an aftermarket rubber sealing weatherstrip so the glass dimensions are likely to be different.
Post #662619 8th Nov 2017 1:27pm
