Home > For Sale & Wanted > [For Sale] 110 tow bar plus bits
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
I have a brand new genuine tow bar for a Defender 110 with plug in loom and 50mm ball collected £70.00 .
One used 110 tow bar with loom and 50mm ball above collected £50.00 .Discovery TD5 sliding hitch type tow bar below,which has the slider bolted instead of pins £50.00 collected.
Four bolt steering box with arm in good condition £50.00 I could send this with Hermes for £7.85
Post #662164 6th Nov 2017 11:14am
JOW240725
Hi Nigel,
I guess the new one would fit a 1990 110? I believe it should have a steel angle that fits below the cross member and bolting through to the second set of holes down, is this included, as I can't see it in the photo?
If it does I might have to have this? See if the old girl is up for a bit of towing or at least recovery!
Thanks James
Instagram @suffolk_rovers
Post #662166 6th Nov 2017 11:35am
legin
Hi Yes I have the steel angle that bolts the rear x member and the tow bracket and the two bolts that fix to the tow backet.I don't know why it was removed.As for fitting your latest purchase ,I think they are all the same.
Post #662197 6th Nov 2017 1:32pm
Mdm
if you could do postage to Lancashire bb4 area., ill have the 110 towpacks
Post #662275 6th Nov 2017 8:55pm
