Home > Puma (Tdci) > Anti Theft-what's the best way?
5wh
England 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
A few threads here and elsewhere have made me nervous about the chances of my SVX being stolen.Easily bypassable factory fit alarm and immobilisor coupled with expensive and valuable parts on my vehicle means that I'm now looking at different methods of preventing this happening.
The options so far seem to be a more effective alarm/immobilisor or a high spec tracking system.Has anyone else tackled this problem?? 2009 SVX 90 Station Wagon
Post #66216 4th Apr 2011 10:49pm
mse
Tracker Yes - work out if you want it as a deterant (eg publish you have it) or a recover tool (eg dont mention it)
Battery backed up sounder to the normal alarm will be fine
Make sure it is difficult to remove doors and bonnets (sealant and wire restraints)
Some form steering wheel guard (disclock or similar)
Good home security when your parking it at home
Sensible parking when your not at home
Good insurance
And your done (and i didnt make any SVX comments)
You could go a little further - like SMART water and anti theft bolts etc... Mike
Post #66221 4th Apr 2011 11:05pm
110SEB
I love our 110 so much I'd happily kip in it in a sleeping bag most nights. That would put the thieves off. A 16st bloke who sleeps like a log would totally block all access to the pedals and prevent turning the wheel better than any clutch claw or disclock.
Post #66224 4th Apr 2011 11:12pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
Where does the "sealant" go? Do you mean a thread lock? And likewise any thoughts about where to mount the wire restraints
I wondered about drilling the bolt heads to remove the pozidriv - bit radical and won't do much for rust prevention
Post #66312 5th Apr 2011 8:39pm
mse
no I dont mean thread lock Thumbs Up Mike
Post #66314 5th Apr 2011 9:03pm
Caterham
sealant.
I mentioned this sometime ago and if your thoughts are as mine the idea was to put silicon sealant in the door hinge recess where the bolts fit. the idea being that before you can remove the bolts (and hence the doors) you have to Censored around getting the silicone out. hopefully before all of this is picked out the thieving scumbag will have Censored off - why do we have to even think about doing things like this (scum bag ar5e holes should be shot or strung up when caught.......ra ra ra !!) Evil or Very Mad
Post #66335 6th Apr 2011 7:19am
mse
Caterham wrote:
sealant.
Yes i suggested that in about 08 - its the way forward Mike
Post #66393 6th Apr 2011 5:18pm
SteveS
I get it......sealant is a neat solution - certainly better than drilling the heads out.
What about the wire restraints on the earlier post.....how does they work?
Post #66413 6th Apr 2011 8:42pm
noworries4x4
plastic covered steel wire bond ie like a motorbike lock tucked over the internal bracing under the bonnet and locked to the engine lifting point only enough slack so you can get you arms under to lock it and unlock the restraint If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #66422 6th Apr 2011 9:37pm
If someone was to Market a bonnet lock I think they would sell loads!
Older 109's used to have them. Maybe an electrical solenoid lock would do the trick ? Just a thought.
Ashcroft are the transmission experts maybe they could come up with some sort of transmission lock?
I used to have Yale dead locks on my escort rs2000 (mk2) you don't see them for sale anymore.
Post #66432 6th Apr 2011 10:22pm
