Home > Td5 > TD5 Mileage
Page 2 of 3 <123>
geobloke
Martin 01 wrote:
Bought my Defender with 180,000 on it all ran fine until recently @ 235,000 miles.
Just had new gearbox, transfer box, clutch, flywheel & associated parts.
All seems to be going good again now. Thumbs Up
It all depends on how it’s been treated throughout its life I suppose.
Blimey good going Martin... Thumbs Up Thumbs Up
Post #661797 4th Nov 2017 10:50am
Martin 01
I’m sure there are more out there with bigger mileage than mine.
Very Happy
Post #661894 4th Nov 2017 9:58pm
tony.g
What's happened to the decimal point on the odometer?
Post #662292 6th Nov 2017 10:27pm
geobloke
Decimal point disappears after 100,000 is reached.
Post #662296 6th Nov 2017 10:41pm
tony.g
'S'pose that's logical really, to give a true indication of mileage.
At 235K you're nearly the distance to the moon!
Post #662306 6th Nov 2017 11:17pm
Avion8
Australia 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
[quote="geobloke"]Oh good grief Avion you've gone and done it now mate... The local Indy owner has a saying: if it has reached this age/mileage then its a good engine...
If you are concerned do a coolant block test, its completely non-invasive. I used Dr Block Tester (eBay). worked a treat, easy to use and diagnosed a head gasket issue with my 15P. Actually quite a good idea to do this at a service interval as it is so easy and good for peace of mind.
Thanks geobloke, I found a similar product Block Check from the USA on our Aussy eBay, so may give that a go - next year! 1955 Series 1 107" Pick up.
1977 RRC Suffix 'D'.
2000 Defender 110 TD5 Xtreme.
2015 Defender Heritage 90.
Post #662327 7th Nov 2017 2:02am
AJC
Mines about to turn 90,000. Quite reassuring that It sounds like it'll keep plodding on and on
Post #662334 7th Nov 2017 7:40am
roel
I am 93000 Miles right now. So my engine will survive but what about the rest of my 90? Twisted Evil
 Roel
2003 90 Td5 (2009-now)
Post #662338 7th Nov 2017 8:07am
Djcla
Mt td5 15p is on 172k runs ok, not aware of it having had any major work. What's signs of the gear box going btw?
Post #663574 11th Nov 2017 10:22pm
Gerry
That'll test the tree sliders Smile
Post #665292 18th Nov 2017 3:04pm
roel
I was doing this:
But then lost grip and slided down. For a while it went ok. I was pulled off the side by a winch but then after a while I run out of diesel. So then the Jeep on the left pulled me out from the front.
No real damage done and the cage was tested and found strong enough te be winched on. Smile Roel
Post #665298 18th Nov 2017 3:20pm
bos
Slovenia 2012 Defender 90 Puma 2.2 CSW Sumatra Black
270.000 km, new discs, clutch
Post #670576 12th Dec 2017 7:48pm
lightning
But as Defenders last for ever, how long before one gets to Mars?
Post #670604 12th Dec 2017 10:16pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Mines 11 years old with 105k on it.
I used to worry about too much mileage but not now (had my defender for 4 years now and put 40k on it) and it runs really well. The more I get to know the vehicle the more mileage is unimportant as long as you keep on top of problems and use quality filters and fluids.
so, don't worry about mileage over 100k Thumbs Up
Post #670787 13th Dec 2017 9:33pm
Journal Photo
United Kingdom 2006 Defender 90 Td5 CSW Indus Silver
Hi Mike,
I have a TD5 Defender 90 2006, I have had my little darling since 2006 when the clock was showing 53 thousand, I now have 10016 thousand, oil change every 6 months and I replace things as soon as advised. I do not want it to stop, I just love it. I had a new clutch put in at a 10015 thousand and a new fuel pump in at 57 thousand not long after I had the Landy. These are all miles, not KM.
Post #725547 26th Aug 2018 10:09pm
Page 2 of 3 <123>
