![]() | Home > Technical > Rear step install cross member holes issue ( FIXED) |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
You can't, which is of course why threaded inserts were used n the first place.
You have limited choices really: 1. Cut an access hole in the crossmember to allow spanner access (highly un-recommended!). 2. Find some sort of captive nut plate you can get in the crossmember (difficult but not impossible, but probably involves cutting an access hole so also highly un-recommended). 3. Install larger threaded inserts, if necessary using larger machine screws for the towing attachment afterwards (easy, quick, and low risk). I know which I would do. Remember that you don't actually need a tool for setting threaded inserts, just a suitable long-ish machine screw, a nut, some washers, and three hands. |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 ![]() ![]() |
so Option 3 , you mean just move up to M10 size rivnut if its a good fit and say and use an M10 bolt instead assuming it not to big for the step holes?
Yes. If need be you can enlarge the hole to take the larger size M10 rivet nut, and set the insert with the bolt and nut technique. You may have to enlarge the hole in the step to take the M10 screw.
If there is some unexpected reason why you really cannot use a larger thread-size rivet nut, then you may be able to find an M8 rivet nut with a larger outside diameter, a larger head, or even a hex body which, with careful filing of the hole, you may be able to use. If you have a look here you will get some idea of the wide choice available. You may want to look at the "swaging inserts" page as well, since the crossmember may well be thick enough to use one of these. |
thanks the M10 rivnuts i have are still a little too small for the hole by a 1/2mm and i dont think the flange will grip enough. so perhaps i need to find some with a bigger flange.
Could you move the step an inch or so to the nearside and drill two new holes?
Could you attach the step to a plate, and attach the plate to the crossmember using fixings in a slightly difference location? Isn't it curious how sometimes the jobs that seem as though they should be the simplest on a Defender end up being the most hassle! |
i did consider moving the holes left a littke but it will be pretty close to the high lift jacking point / hole , ill have another look and take a pic, but this is from the gallery and shows the distance
https://www.defender2.net/gallery/albums/u...member.JPG |
right ive order some m12 rivnuts as i think that they will be nice and snug in the holes , just need to now learn how you install them without a special tool
Before making an irreversible action I would suggest you carefully drill out the existing rivnut without enlarging the hole.
A m10 rivnut needs a hole size ranging from 12.7 mm up to 13.5mm dependent if rivnut is ali, steel, ribbed, round body, thin sheet etc. So it might be possible by selection of appropriate rivnut you might not have to go non standard size. Have a look at http://www.memfast.co.uk/shop/Vprod1.asp?cat=3882001938 for sizes. Brendan |
@leeds Thank you for the tips , there was no rivnuts in the holes just bolt and a nut the other side , i think in past life someone has bodged the holes as they are way to big now for an M8 and an M10 is quite loose as well , ill try and work if my rivnuts are 13.5mm hole size but i have a feeling an m12 might just go in the hole with no drilling.
The M12 rivnuts fit the hole a lot better. Fitting them is a little challenging trying to do it without the proper tool upside down and keeping the rivnut in place. Might find a local garage and see if the have the right rivnut tool for the job.
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737 ![]() ![]() ![]() |
Not easy unless you have three hands!
Not having the proper tool, I practised on a spare bit of metal to get a feel for how the rivnut grabbed the metal before doing it on the crossmember. Have you someone who could help and hold things in place, before resorting to the garage. |
I did yesterday but still pretty hard to do and keep everything in place, thinking of glueing rivnut in place first to stop it moving about might help.
well in the end i just bought the long arm version of the sealey riv nut tool for £63 to add to the short arm version i bought recently lol
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
The memfest tool is the best on the market (£100
