![]() | Home > Td5 > Clutch Problems |
Yea topping up should be fine
![]() Most likely be the slave cylinder leaking which is an easy job. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
TechnoTurkey Member Since: 25 Jul 2016 Location: Worcestershire Posts: 88 ![]() ![]() |
Easy apart from bleeding it!
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 ![]() ![]() ![]() |
Use reverse bleeding. Introduce DOT4 from below using a large syringe and make sure to get some out of the reservoir so it doesn't spill.
Also, it apparently helps to get rid of the air by keeping the pedal depressed for a night. Greetings, Joris |
DieselBeast Member Since: 27 Sep 2017 Location: UK Posts: 33 ![]() ![]() |
Is the Td5 clutch slave cylinder the same external type as the 300 tdi?
Low-Range Member Since: 30 Sep 2016 Location: BC Posts: 41 ![]() ![]() |
You can also use the old school oiling can with a little flexible tube to push up fluid...no air trapped in line.
AND IT"S CHEAP |
clutch slave cylinder in TDI engines ftc 3911 To V TA 9975715 + FRC2402 ftc 5072 to G 56A 0669086K + FRC2402 ftc 5202 from G 56A 0669086K + FRC2402 clutch slave cylinder TD5 FTC 5202 TD5 |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3243 ![]() ![]() |
After you've fitted new parts and bled the system, you will most likely find that no matter how much you bleed/reverse bleed it, the clutch engages right at the bottom of the pedal.
Wedge the pedal down overnight and that should sort it. |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Just what you had to do with
the old minis |
LinDens90XS Member Since: 25 Feb 2012 Location: Merseyside Posts: 83 ![]() ![]() |
My penny worth. It may be just as well to change the master at the same time as when one goes the other is never far behind. Regards
Dennis. |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002 ![]() ![]() ![]() |
I recently had a new clutchfix HD1 clutch and valeo dmf fitted I have noticed bitepoint very low to floor but also that the pedal has drop a inch or so and does return right to top position. You can move the pedal up a bit with your foot, any advice? Would this be sorted by wedging pedal down over night as lightning suggests
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Never tried this but next time I will..
So I thought to catch air bubbles in the line from the syringe/oil can install a t-joint with a short section of terminated hose at the apex of the hose. ![]() |
Try it tonight and see! It has always worked for me. |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 975 ![]() ![]() ![]() |
Defo sounds like you’ve got a slave or master leak. Check fluid level, fill and bleed then determine what is leaking and replace or rebuild. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
