![]() | Home > Td5 > Td5 not starting |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
What is your voltage while starting? If it is below 9V somewhere ecu shuts down and it will not start at all.
The engine will be cranking but it won't start. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461
Not 100% sure but he has a brand new lifetime warranty halfords battery and a split charge, and it whizzes round very quickly. He's tried split charge disconnected isolated and connected all to no avail. 1998 110 300Tdi White Hard Top
| Dieseljock Member Since: 03 Jun 2017 Location: Inverclyde Posts: 32
Have you tried bump starting it had this before would crank over until the battery was dead but would fire right away with a tow, turned out the starter was corrupting the crank sensor signal which we could view on the nanocom. The signal was erratic on cranking but perfect when bump starting. Changed the starter and boom problem solved
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
Have you got the small spacer shim fitted to the crank sensor ?
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
| JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190
Could it be the rubber dobries on the dampener on the aux belt drive stuff. Sorry for being technical but the brain is dead from a day at work. I am just thinking of a mate who sourced a rough running Freebie to the crankshaft pulley/vibration damper.
The other is to ensure the engine has a good earth otherwise it tries to use the loom. Had this with the disco. ![]() |
| Iain_S Member Since: 03 Sep 2014 Location: West Lothian Posts: 8
My TD5 starting was much improved by running an extra negative wire from the earth point in the ECU compartment to the battery.
Thanks guys, he gave up and took it to local specialist.
Can't quite remember what the issue was, but it starts a treat now. 1998 110 300Tdi White Hard Top |
| Gerry Member Since: 22 Oct 2017 Location: north Ireland Posts: 35
If it's not too much bother can you find out and post what the issue was.
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
A low voltage while cranking stops the fuel pump relay (rear yellow one) from closing.
Rest your finger on it while cranking. If it vibrates you need a new battery. (Guess how I know ![]() |
