Home > In Car Electronics > Easy speaker upgrade
stephan123
Hi,
I have Defender 90 XS with the Alpine sub and I am looking to upgrade the rest of the speakers. Ideally I would want something that is plug and play as I am not too handy with electrics/cabling.
Any suggestions would be much appreciated.
Many thanks
Post #661652 3rd Nov 2017 3:43pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I personally love the focal range - but the choice is yours depending on budget. Speakers are very much get what you pay for. They aren't very difficult to fit, if you want to upgrade sizes and go bigger you'll need to start cutting plastic etc.
Where are you located? My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #661654 3rd Nov 2017 3:51pm
zsd-puma
LRI solutions do upgrade kits. They're not quite plug and play as you have to cut the ends off the existing speaker wires and put them into the cross over box, but it's very easy to do.
Post #661738 3rd Nov 2017 10:50pm
Baldinho
United Kingdom 2013 Defender 90 Puma 2.2 SW Orkney Grey
Second the Focal recommendation. Straight (ish) swap for all speakers and a reasonable upgrade in sound bearing in mind the acoustic limitations of the Defender.
Whereabouts are you in London as can give you a couple of dealers if you want them to fit for you?
Post #661749 4th Nov 2017 12:04am
stephan123
I am located in North London. The Focal range looks good although I would rather try and fit them myself. Are they a straight swap? Current speakers look straight forward to remove with the exception of the tweeters on top of the dash (no screws visible). Any idea how to swap out the tweeters?
Post #661818 4th Nov 2017 12:59pm
Martin
Site Admin
I think the tweeters push out  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #661822 4th Nov 2017 1:51pm
Baldinho
Yes a straight swap. Push the tweeters out from underneath. Focal tweeters are a bit of a snug fit so be careful when putting them in
Post #661836 4th Nov 2017 3:26pm
