![]() | Home > Technical > Td5 90 - Duck under the bonnet! |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Try spraying all the wheels on the serpentine bells with spray oil alternator ps pump
TD5Neil Member Since: 02 Nov 2017 Location: Cambridgeshire Posts: 42 ![]() ![]() |
I think I may have the same issue. Woop woop rubbing noise, intermittent, persists for a while and then gone for a couple of weeks before returning. Worse when cold, gets better when warmed up. Sometimes starts up when turning to the left, eases when backing off throttle. Worse if it's been wet, started up again after a wash and been with me for a couple of days. Checked wheel bearings and swivels for play, also UJ's. Really odd it can go away for 2-300 miles and then return.
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 ![]() ![]() |
i have a similar noise first thing when i put my foot on the clutch but it goes away once warmed up and i assumed it was the Dual mass flywheel or something . I just turn the radio up
That’s clutch release bearing very common
sawtooth tyre wear noise
https://www.oponeo.co.uk/tyre-article/saw-tooth-tyre-wear had same problem |
Djcla - your noise does sound like release bearing. My noise goes when clutch depressed.
Dorsetsmith - would sawtooth tyre wear be intermittent? Ibexman - I'll look at the belt True to it's intermittent nature no noise on the way to work today. Previous 3 days it was there! |
Is that a cheap job to get done or are you better off doing the clutch etc at same time? I got 170k on clock and not aware of any major work in its past. |
Diffy Member Since: 04 Oct 2015 Location: Taunton Posts: 6 ![]() ![]() ![]() |
Timbotim - when you say you regreased the swivels do you mean you refilled them with one shot?
Reason I ask is I had a very similar sound noise somewhere between a duck quacking and a seal begging for fish ! Seemed to occur at low speed when turning left My noise was banished by refilling both swivel hubs with one shot - both of mine appeared to be dry |
