Home > For Sale & Wanted > [Wanted] Ultragauge.
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Driving home tonight, my ultragauge was stuck on the "scanning" start up page,
Shortly afterwards the Defender went into limp mode, with the common battery light on, temp gauge into the red, and no rev counter.
I pulled over, disconnected the OBD plug, and away I went with no issues.
So I'm thinking the ultragauge is dead!
It's built into my dash, so it's on all the time the Defender is in use, maybe it's too much for it,
I don't know?
It's lasted 3 years up to now!
If anyone has one that they no longer need/use, I could give it a good home.
Not worried about box/packaging, cable, or condition of external case,
As long as it works internally, as I will pull it apart anyway!
Ian 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #659785 26th Oct 2017 6:51pm
DAZ110
Ian,
Are you sure you’re existing Ultagauge is dead?.....maybe just a bad connection to the OBD? Why don’t you try plugging it back in again, turning on the ignition, let it do its scan and see if it comes back to life?
Post #659806 26th Oct 2017 8:41pm
ian series 1
I did have a play about with it when I got home,
It stays on the "scanning page" for a good 5 mins, then displays a page with error, the buttons do not work as they should?
If you press the menu, it goes back to scanning?
I've plugged other diagnostics in to the OBD, and it all works fine?
If you start it with it connected, I get the faults with the cluster, and limp mode.
Surely It has to be the gauge? 80" 80" 86" 88" 90"
Post #659810 26th Oct 2017 8:57pm
DAZ110
Does sound like it.
Are your radio and interior lights working ok?...just a thought as the OBD is on the same fuse 10 amp (F30) I think? Might be worth pulling it out and putting it back in again and see if anything happens.
I only say this because my radio wouldn’t work the other day and I pulled the F30 fuse and put it back in again and the radio came back to life....???....and my Ultagauge then did its scan and re-started, and all was ok again.
Post #659814 26th Oct 2017 9:23pm
ian series 1
Interesting?....
Cheers for that info,
My stereo has been fine, and the lights, but I will check the fuses,
I will have another look at the OBD plug at the weekend.
It's a pain that it's in the dash, as I could have plugged it in to another car!
Thanks again for the advice Thumbs Up 80" 80" 86" 88" 90"
Post #659817 26th Oct 2017 9:29pm
DAZ110
Good luck with it. Let us know if you identify the problem.
Post #659821 26th Oct 2017 9:35pm
ian series 1
Will do, cheers Wink 80" 80" 86" 88" 90"
Post #659830 26th Oct 2017 10:00pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
out of interest, how did you have it powered? Was it on an ignition feed, or constantly on (even with ign switched off) ? My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #661420 2nd Nov 2017 2:34pm
