Home > Puma (Tdci) > Diesel leak
Greyman110
Diesel leak
I topped my tank up for the first time and noticed a faint diesel smell after driving home which I put down to filling up 2 mins before.
I drove for 30 miles today and the smell was stronger when I got out. Looking under the car the top of the tank looks to be wet. The fuel gauge still shows full so it seems its weeping from somewhere.
Took some pics in the dark so not great but any help appreciated.
Post #661305 1st Nov 2017 11:12pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Ahhhh an old classic Wink
More than likely it'll be your fuel tank breather. There's a decent sticky about it. Land Rovers top quality parts again unfortunately.
Have a read through the sticky and any more questions feel free to ask, as I've just had to do the job on my 110 DCPU.
Thumbs Up
Post #661309 1st Nov 2017 11:20pm
Greyman110
Ahhh...thanks for that!
Gives me something to try and sort out tomorrow now Rolling Eyes
Post #661312 1st Nov 2017 11:28pm
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
You probably overfilled it, need to stop at first click, let the foam subside and then do another click or two.
If you keep going until it's filled near the top of the filler tube it will come out the breather.
Even tho I know this, I still tend to over fill, especially if I'm going to be driving straight off on a long journey.
Bad habit.
Post #661316 1st Nov 2017 11:49pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
I had something similar, but only leaked when parked on the drive which has ever such a slight slope. Turns out the breather was fitted facing the wrong way round Rolling Eyes 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #661319 1st Nov 2017 11:51pm
BenB8man
Was that breather fitted the wrong way round from the factory Rosco? I couldn't quite decide which way round it should go when I was fiddling with mine. Seemed to flow in both directions, so I put it back as it came off.
Post #661323 2nd Nov 2017 12:34am
zsd-puma
the breather was just too short for a start and the hose was made out of rubbish quality rubber so it splits.
There is a revised longer breather now, just order a new breather hose and you'll get the latest long one that straps to the side of the filler hose.
I did mine it wasn't too bad, had to release the front mountings on the tank and lower it down slightly on a jack for access from the wheel arch. The worst part is snapping the old hose clip off the tank, as it's only of those single use clip together stainless band things. Once that was off it was just a case of pulling the old hose off, pushing the new one on along with a jubilee clip - which is much easier to do up with a small rachet and socket. the jack the tank back into place and resecure everything. Cable tie the breather hose to the side of the filler hose.
Be prepared to get filthy, as there will be diesel and dirt mix all over the top of the tank.
Post #661330 2nd Nov 2017 2:01am
agentmulder
Kuwait
Yeah, it's not the most fun of the typical Defender ownership badges one eventually accumulates... Solved the bowel problem, working on the consonants...
Post #661335 2nd Nov 2017 4:57am
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
All Pumas will leak on overfill but mine was badly perished at the filler cap end only noticed it when i changed the rubber gasket around the filler neck. At 6 years old too.
Post #661381 2nd Nov 2017 10:37am
