Home > Puma (Tdci) > Getting diesel to Eberspacher heater on 2.4
ScottDab
United Kingdom 2008 Defender 110 Puma 2.4 HT Alpine White
Has anyone fitted a diesel heater to a puma? If so where is the best place to tap into for diesel?
Can i put a T piece in the fuel line between the filter and the engine?
Thank you in advance
Post #661349 2nd Nov 2017 8:02am
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
I haven't yet completed it, but I have bought an insert for the fill pipe. It cuts in, and then has a pipe that feeds into the tank. I can try and find a link later. V8 90...WIP
Post #661362 2nd Nov 2017 8:59am
Paulv8
Just found this from a quick google. It's not the same supplier, but the same thing and gives you a starting place
https://www.butlertechnik.com/installation...252a-p1291
I spoke with a supplier and they said the td5 one should fit fine. As I say, not done it yet, but need to now the weather is getting chilly! V8 90...WIP
Post #661364 2nd Nov 2017 9:03am
ickle
I put a dip tube drilled through the level sender plate. Got access by carefully cutting an access panel through the rear floor, there's a link on doing it on a 90 somewhere on here - IIRC Danielle (DGardel) did it and posted pictures.
Post #661366 2nd Nov 2017 9:09am
leeds
Choices are various.
Tee piece into fuel line from tank. However I would not recommend that as you could land up with an empty main tank.
Alternatives are fuel pick up via fuel filler hose. Look here
Can get a fuel pick up direct to tank such as THIS
Or a separate diesel tank for your heater 13 litre here or 7.5 litre here
HTH
Brendan
Post #661377 2nd Nov 2017 10:21am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
The best thing to do is to use the fuel filler scavenger that dips into the fuel tank from the filler hose, its a 10 min job and even an unskilled thumb fisted like me managed it with no issues. I have done this to both 110’s and with 2 different heaters.
(The one on Brendans link is similar to the type I’ve used, but mine was from another manufacturer http://www.4x4overlander.com/product/diesel-fuel-pick-up-pipe/)
hope that helps Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #661392 2nd Nov 2017 11:58am
Laurie
Why not fit a small seperate tank and run it on much cheaper 'red' diesel?
Post #661393 2nd Nov 2017 12:10pm
Paulv8
If you wanted the correct separate tank - I happen to have one I can sell you Smile V8 90...WIP
Post #661398 2nd Nov 2017 1:11pm
JWL
Exactly what I do Laurie Thumbs Up
I use an old header tank from a Focus that was being scrapped and fitted it under the bonnet next to the heater box. It probably holds just under 2 litres but will run my Eberspacher for a good 18 hours
Post #661512 2nd Nov 2017 9:34pm
ScottDab
Thank you for the replies,
I think i am going to go with the scavenge pipe in the filler neck. Will save me having to remember to fill another tank!
Post #661579 3rd Nov 2017 8:01am
