Home > Maintenance & Modifications > Degreaser
Page 2 of 2 <12
smb
zsd-puma wrote:
Comma Hyperclean. Spray on, agitate any really heavy greasy bits with a stiff brush then wash off with a watering can. Doesn't leave any oily residue like white spirit and goes a lot further than alcohol (brake cleaner).
While its still wet if spray everything under there with Autoglym Vinyl and Rubber care, when it dries itll look like it came out of the factory.
Here's my 7 year old 80'000 mile engine bay...
WOW Shocked
Post #660859 31st Oct 2017 10:40am
zsd-puma
it was pretty oily under there where the injector seals had been blowing oil mist everywhere. I suppose it took about 15 min to clean it and get it looking like that. It lasts well too.
Post #660865 31st Oct 2017 11:21am
ChrisDefender
Hi.
Is there anywhere you shouldn't spray that stuff under the bonnet, or can it go all over and then gently rinse off.
That looks superb mate.
Post #660895 31st Oct 2017 2:23pm
zsd-puma
i just slosh it everywhere.
So long as you don't use a high pressure lance to wash it all off again. The only problem i've ever had is on petrol engines where the plug leads have made the engine miss a bit where they're wet, but just leave it to drain off a bit before running the engine and all is fine. The Autoglym vinyl and rubber care i just spray everywhere, it's not caused any issues. If you just wash it off with the hyperclean it'll leave the plastics looking a bit dull and grey but it doesn't hurt them.
Defenders are designed to be driven through floods after all, so low pressure water on the outside of the engine isn't going to do it any harm.
Post #660922 31st Oct 2017 4:58pm
Page 2 of 2 <12
