Home > Maintenance & Modifications > Chassis Treatment DIY products
Djcla
oh my there is a lot of products and info out there on the interweb so here goes...
Im contemplating the horrible job of potentially DIY rust poof / treatment my 90 chassis inside and out and just not sure what to get Sad ie buzzweld, dinitrol etc and the vast array of different products they do. SO whats the feeling on here for doing this job and what did you go with and why?
Post #660683 30th Oct 2017 8:42pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
Dinatrol kit on drive at home
Post #660690 30th Oct 2017 8:59pm
nitram17
I think dinotrol is a clear winner on here..although i went with bilt hamber stuff ..just for ease of use and slightly less messy!I also coated nuts and all running gear with acf grease and my crossmember is swiming in acf spray...good luck
https://www.bilthamber.com/corrosion-prote...reatments/
I think the key is to top up the treatment (whatever you choose)and preperation....i like fertan to get rid of the rust!
Post #660692 30th Oct 2017 9:04pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Waxoyl because my dad doesn't trust new things Laughing
Waxoyl is easy to use, so if I was going to DIY it, i'd use it again but if I were to pay someone else I would get Dinitrol 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #660694 30th Oct 2017 9:05pm
Devon-Rover
I went with Bilt hamber after lots of research and actual proof of quality with scientific backing versing a lot of anecdotal hearsay.
Shameless self promotion >>>
My rustproofing guide. Wink
Post #660701 30th Oct 2017 9:19pm
zsd-puma
Unless its cold. Laughing
I used to swear by the stuff, but after trying Dinitrol i've never looked back. It doesn't need standing in a bucket of hot water to make it fluid enough to spray, it doesn't smell as bad, it doesn't start dripping out on the first warm day of the year, it doesn't attract dirt, it doesn't wash off so easily and it skins over so you dont get it all over you when you brush against it.
Dinitrol is easy if you can borrow a compressor, but you can do it with their aerosols too.
Post #660704 30th Oct 2017 9:23pm
Djcla
Also want to be able was underneath chassis without the risk of it coming off , whichever product I coose
Post #660710 30th Oct 2017 9:45pm
UtilityTruck
There are lots of opinions on what's best, I also went with built hamber- I have no proof it's the best, however I don't like the finish offered from waxoil or dinitrinol so the clear bh stuff was a go to option.
Granted I first protected my truck from new, but after 50k miles and 3 years I'd say the chassis is still tip top.
The pic above was at the end of this summer when I thoroughly cleaned it off and reapplied. I touched up the rear axle and front outriggers(where they take stone impacts from the front wheels) with some chassis black and everywhere else was simply cleaned. 2014 Keswick Utility 2.2
Post #660716 30th Oct 2017 9:53pm
Djcla
I like Bilt hamber stuff so interested in that and want a nice black or brown finish if possible.. which products are required from their range?
I'm also thinking of using fertan rust convertor inside the chassis first and notice they do a clear cavity wax which makes more sense. Then use something else on the underside externally
Post #660734 30th Oct 2017 10:34pm
Devon-Rover
Simply the Dynax S50 is for cavities and box sections, The UB is for general underbody use and is brown coloured, the UC is the same underbody but clear.
IMHO if you have an immaculate underside then the clear will work lovely and look great too and help in keeping tabs on any future issues. The brown covers more as like I did with a chassis that was just about to show signs of rust and visable paint issues, so the clear just wouldn't cut it. Any future issues will have to develop a little more before they are spotted that is the compromise. But for me and the interests of my channel I will conduct inspections and report my findings.
before
after
Post #660760 30th Oct 2017 11:23pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Devon - Is that "after" picture using the UC or the UB?
I have used UC on mine since I got it at a year old. With the harsh Winters and heavily salted roads I need to top it up every year. I wonder if the UB will last longer?
Post #660763 30th Oct 2017 11:32pm
Devon-Rover
That is UB on all the chassis external and UC on the inner rear arches and under floor pans. Essentially if it is body coloured then it had UC on it, if it was painted black then it went UB.
In my research on here someone directly asked BH and they quoted that UB had better anti abrasive qualities. I would suggest an e-mail to BH to ratify this as they are very helpful.
HTH
Post #660771 30th Oct 2017 11:44pm
Kit
True! To be fair I purposefully did mine during the hot spell we had 1993 200 Tdi 90 CSW
Post #660781 31st Oct 2017 12:05am
Djcla
@Devon Rover , how much of each product did you use / buy to do the ? Defender. Did you use the POR 15 top coat after wax?
Post #660891 31st Oct 2017 2:14pm
UtilityTruck
I can't speak for DR but I used 2x cans of UC and 2x of the S50 in the chassis legs. To do a really thorough job, an additional can of each would be handy.
Any paint, including POR should go under the protective coating. 2014 Keswick Utility 2.2
Post #660896 31st Oct 2017 2:34pm
