Home > Maintenance & Modifications > Degreaser
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Degreaser
Any recommendations on the best degreaser for under the bonnet so I can try and stick the insulation back on.
Cheers BM52
Post #224461 3rd Apr 2013 10:50pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
Bilthamber surfex HD is very good and good price in 5l too..
http://www.bilthamber.com/surfex-hd
Post #224468 3rd Apr 2013 11:45pm
SteveG
By the way for just cleaning up to restick insulation, panel wipe spray may be easier and easily sourced from Halfords or motor factors
Post #224469 3rd Apr 2013 11:48pm
How about IPA / Isopropyl alcohol? That's a good degreaser and general cleaner. Safe on paint too (Well I've used it)
http://www.ebay.co.uk/itm/IPA-ISOPROPYL-AL...257983b5b9
I usually use small wipes as never needed to use on a larger area but no good for your intended use. ___\⭐️Lone|Star|State/___
____\We|Will|Win/___[/size]
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #224470 3rd Apr 2013 11:57pm
LR90XS2011
its worth trying white spirits, or even cheaper and less greasy petrol (just be careful due to fire risk), white spirits makes a great general de-greaser DEFENDER 90 TDCI XS,
Post #224475 4th Apr 2013 6:34am
jst
hot wash and the brake cleaner Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #224477 4th Apr 2013 7:09am
bm52
Thanks for the replies. I have white spirit and brake cleaner so I will start with them.
Thumbs Up BM52
Post #224518 4th Apr 2013 10:08am
smb
Resurrecting a thread from 2013!! Does anyone have any knowledge of the best degreaser currently on the market?
I want to clean down a an old tractor that has just about been subjected to everything. I don't want to use a Hot Pressure Washer and instead will use just a high power cold, but I want to get years of overspill diesel, grease, oils and even blackjack grease in places. Some of the areas covered are very difficult to get to so a sort of penetrating foam would be of great help, but it depends what is available.
Would like to preserve as much of the original paint as possible tho'(hence not using hot pressure wash)!
Many thanks
Steve
Post #660558 30th Oct 2017 1:56pm
Personally I would use a steam cleaner for this. Unless the paintwork is in good condition you're likely to lose it with a pressure waasher of any kind, so the only only real gentle option is a degreaser and rinse. Whilst I haven't much experience with modern degreasers (in the old days it was either Gunk or Jizer, neither of which worked very well), I suspect that it will be hard work cold.
A steam cleaner used with paraffin in the jet will degrease very quickly and well, and with careful use in my experience won't damage paintwork (be very careful round electical and electronic components though).
I will be interested to see what other answers you get, since degreasers must have inmproved over the years, perhaps? Unless they've all bee "greened up" to the extent of uselessness.
Post #660562 30th Oct 2017 2:13pm
Coatesyyy
Smb, all comes down to peoples preferences. I personally use this
http://uk.farnell.com/ambersil/6330001020/...dp/1701184
Absoloutley fantastic!
Post #660566 30th Oct 2017 2:21pm
smb
BW, Im hoping using steam will be the last resort, but will wait and see. Having spoken to Mike Lillar at MSB I may even end up soda blasting.
Coatesyyy, thanks for the link. Ive just ordered some so will be good to see how it does.
Many thanks for your replies Thumbs Up
Post #660571 30th Oct 2017 2:35pm
Coatesyyy
No worries mate, I swear by it Thumbs Up
Post #660573 30th Oct 2017 2:44pm
LR90XS2011
white spirits, spray on leave a few minutes, agitate with stiff brush and wash or wipe off DEFENDER 90 TDCI XS,
Post #660693 30th Oct 2017 9:05pm
zsd-puma
Comma Hyperclean. Spray on, agitate any really heavy greasy bits with a stiff brush then wash off with a watering can. Doesn't leave any oily residue like white spirit and goes a lot further than alcohol (brake cleaner).
While its still wet if spray everything under there with Autoglym Vinyl and Rubber care, when it dries itll look like it came out of the factory.
Here's my 7 year old 80'000 mile engine bay...
Post #660699 30th Oct 2017 9:16pm
BigRuss
Thats one super clean engine! Russell
2011MY 110 XS USW Black
Post #660846 31st Oct 2017 9:46am
