Home > Td5 > Cutting out, strange symptoms
drinkdrinkdrop
Had some trouble recently with my TD5 (2002MY) cutting out without warning, I lose all drive, power steering etc, I don't see any lights on the dash (oil, battery, check engine) and hazard lights wont come on.
I can usually at this point stick the clutch in,turn the ignition key off and back on and be on my way. Anyone else seen this issue and point me in the direction of a possible cause?
Post #660494 30th Oct 2017 10:30am
dorsetsmith
1. check battery earth follow the cable down to chases and transfer box make shore all terminal good and sound
2. check battery POS terminal good and sound
3. check main relay under driver seat, relay terminal can work loss
Post #660495 30th Oct 2017 10:35am
As it sounds like it's been turned off, a faulty switch on the end of the ignition barrel is a good possibility. Darren
Post #660496 30th Oct 2017 10:35am
bankz5152
I had a similar issue on my old 90, turned out to be a corroded main battery earth, fitted a new one fine ever since.
Post #660515 30th Oct 2017 11:31am
drinkdrinkdrop
I saw in this thread http://www.defender2.net/forum/topic56773.html (about a puma) that if the trip doesn't reset to zero it's unlikely to be an earth/battery issue and is more likely main relay or ignition switch, is this true for a TD5 as well?
Post #661149 1st Nov 2017 2:26pm
