Home > Off Topic > Had a bit of a bump 😞
Page 1 of 3 123>
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Hi all ran into back of artic this afternoon with the caravan on the back and it’s done this to rear x member I guessing it’s likely the won’t want to re chassis it do insirance companies just do x members?
Thoughts appreciated 😞😞😭😭
 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #660359 29th Oct 2017 9:31pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
PJ, trust everyone walked away ok.
Have you looked underneath to see if the bracing arms on the tow bar have done any damage to the chassis rails?
There's obvious some damage to the rear cross member, but I'd be concerned that there may be hidden damage further along.
Also worth getting the caravan checked over make sure nothing has rippled there also. 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #660363 29th Oct 2017 9:39pm
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
Oops.
It will buff out.
Post #660365 29th Oct 2017 9:41pm
pj2106
Yes all ok not had chance to look much as aa left us on side of m42 for 4 hours awaiting a suitable recovery vehicle (will not be using them again)
I will have better inspection tomorrow 2008 110 2.4 XS Utility (Hagrid)
Post #660381 29th Oct 2017 10:15pm
JOW240725
Sorry to see this, but at least no one hurt. Battle scars? Neutral Hope it isn't too serious and you get it sorted out promptly. If it needs new chassis then I'd recommend speaking to Matt Spencer at Carriages Auto Services, hear nothing but good things about it. Just speak to Ecosse on here.
Good luck Thumbs Up James
Instagram @suffolk_rovers
Post #660389 29th Oct 2017 10:29pm
leeds
That tow ball looks bent along with the drop plate. I would certainly want the chassis carefully inspected and measured up.
The law of action and reaction, looking at the damage to the towing equipment I would suspect that the caravan A frame/chassis is damaged. They would warrant at least a careful inspection by a caravan mechanic.
Glad no one is hurt. Hopefully the metalwork can soon be sorted out.
Brendan
Post #660394 29th Oct 2017 11:07pm
pj2106
It’s done the whole front end
The rear has folded towbar dropplate under x member and pulled top captive bolts so has blown x member bottom support bars are yet to be inspected but I don’t hold much hope can’t see any kinks in the chassis but closer inspection tomorrow may reveal different
It may be down to the insurer whom they want to inspect/fix it so will see tomorrow 2008 110 2.4 XS Utility (Hagrid)
Post #660420 29th Oct 2017 11:48pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Ouch glad everyone is okay, i'll just echo previous points and say that the chassis needs to be thoroughly checked before you make any decisions about putting it back on the road. 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #660425 29th Oct 2017 11:54pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Glad all ok. The garage that the insurance company send it to should "drop test" the chassis, this involves lots of chalk and a plum-lime, might be lasers now? My job still uses the old school approch, this shows if the chassis has twisted at all. If it is and they say it's a write off not sure how the insurance would react to you providing a galved chassis. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #660434 30th Oct 2017 12:17am
pj2106
Not sure where they will want to send it yet got those calls to make today 😞 2008 110 2.4 XS Utility (Hagrid)
Post #660471 30th Oct 2017 9:18am
leeds
PJ, insurance companies tend to use their preferential repair centres. (Read that as they get the best rates from, not best work!)
I would suggest you hold out for getting it inspected at a Land Rover specialist rather then the insurance general repair shop.
Brendan
Post #660489 30th Oct 2017 10:12am
Balvaig
I agree with Brendan's comments re specialist bodyshop. But - insurance companies will write off a vehicle if the costs are too high against the book value of the Defender. Any chassis damage will probably result in a write off. In that case the insurer will offer you a settlement figure and sell on the Defender. You can at that stage offer to buy back the written off vehicle.
This would enable you to re-chassis and repair, although the value of the restored vehicle will always be lower as it will always recorded as a write off.
Hope it doesn't come to that and you can get a good repair.
Post #660497 30th Oct 2017 10:37am
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I’ve recently had a similar amount of damage to the rear of my 90 (not quite as bad, but very similar), a bit of feedback from my experience;
- Ensure you pick a body shop that you trust and knows their way around a Defender. If you don’t know any, ring a couple of local LR dealers and get their recommendations of where they use.
- Don’t let your insurance company dictate where it goes – it will be totally your choice who repairs it.
- Mine has similar rear damage (no front) plus the tailgate. The tow pack (plate, ball and straps) are all replaceable (obviously) and the X-member repairable, but the body shop who have mine were concerned that the energy had gone up through the tow support straps and into the chassis.
They inspected all the welds and mounts and after a thorough check found that because the straps had buckled, the hit hadn’t caused any damage to the chassis. So that’s what you need to look out for.
- He also mentioned that even if it is financially viable, if the body needs to come off for the repair the insurance company most likely wouldn’t accept the repair, apparently they wouldn’t consider the Defender repairable due to the unknown scope and warranty of such a large job….so prepare yourself for the worst I’m afraid. My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #660507 30th Oct 2017 11:02am
pj2106
It’s with a-plan/markerstudy on a specialist policy so they have assured me it will go to a 2008 110 2.4 XS Utility (Hagrid)
Post #660508 30th Oct 2017 11:02am
simon67
England 2004 Defender 90 Td5 HT Rutland Red
Mine is going to a Land Rover bodyshop
Post #660531 30th Oct 2017 11:57am
Page 1 of 3 123>
