Home > Maintenance & Modifications > Refurbishing Roof Rack
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
I have a well used and weathered Hannibal rack that is looking past it’s best. I want to refurb it and have been considering going down the anodising route. I guess that could be expensive but my first problem is so far I’ve been unable to find somewhere that can handle an item this size. The top plate is 1700x1400mm.
Has anyone else here had a roof rack anodised or can recommend a firm able to take on this type of work?
Post #660184 28th Oct 2017 11:47pm
leeds
Have a few words with the guys at Specialised Coatings in Halifax.
1.7 x1.4 m is not too large for them.
Not sure if they do anodising but worth a phone call and they are relatively local to you.
They do a lot of work for North Sea oil rigs, mobile cranes and roll cages.
HTH
Brendan
Post #660225 29th Oct 2017 10:30am
rockster57
Brendan, thank you for the pointer. Nothing obvious on their website relating to anodising but as you suggest, worth an enquiry on Monday Thumbs Up
Post #660300 29th Oct 2017 5:11pm
leeds
If you can speak to Paul there, (owner/director) if he can not help/advise you I will be surprised.
Paul used to own/race Defenders so has knowledge/experience about Defenders.
I know they treat roll cages for a respected roll cage manufacturer.
Why anodise rather then powder coat rack?
Brendan
Post #660303 29th Oct 2017 5:28pm
rockster57
Brendan, Powdercoat is another option I’ve been considering and tbh I’m still on the fence. My interest in the anodising comes from a suggestion that it will be more durable and scratch/chip resistant than a powdercoat finish? Not sure just how true this theory is though? I’m wanting to go from the natural aluminium colour to black and don’t want the rack to start to look tatty as soon as I start using it.
Post #660315 29th Oct 2017 6:14pm
leeds
I have no personal experience of getting items anodised so no recommendations or comments about that process.
Powder coating, we do have some items powder coated for us.
The difficulty with a process such as powder coating is the pretreatment and temperature control.
Now most coating processes do not like thin sharp edges as the coat gets 'thin' on the very edge. Coatings prefer large rounded edges.
Good powder coaters bead blast, undercoat and then top coat. Apparently the time between bead blasting and coating is important as the metal can oxidise which apparently affects the adhesion of the powder. Get the heat treatment wrong then the adhesion of the coating to the metal substrate is compromised
Like most things some firms are cheaper and skim on the preparation processes.
I have seen the Specialised Coatings ovens etc. They have some items in from us this week. There are some local firms who we will not use.
HTH
I am no expert on coating, it is what I have picked up talking to coaters and our suppliers
Brendan
Post #660344 29th Oct 2017 8:34pm
rockster57
That helps very much Brendan, thank you for taking the time and trouble to share your experiences/knowledge.
If I decide to go down the powder coating route, I’ll happily follow up your recommendation.
Thank you again,
Peter
Post #660367 29th Oct 2017 9:49pm
JOW240725
I'd be interested to hear how you get on. I've just got an 8yo Hannibal which is in OK condition but some corrosion and paint flake. I was considering re-powder coating but was concerned about both stripping and powder coating in the fixing channel. The fixing bolts are a pretty tight fit and if I was concerned if it didn't go right you'd be stuck. James
Instagram @suffolk_rovers
Post #660402 29th Oct 2017 11:24pm
rockster57
Hi James, I’ll update this thread once I’ve made some progress. Fortunately I don’t have the same problem since my Hannibal is an earlier version without the fixing channels. However, if you go ahead and then discover there’s insufficient channel clearance for your fasteners (8mm?) could you not lightly file a couple of opposite flats on the bolt heads?
Post #660417 29th Oct 2017 11:42pm
