Home > Puma (Tdci) > ABS and TC light on
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
ABS and TC light on
The Nanocom tells me: Front left inlet valve short to ground.
Can someone tell me how to fix this ???
Regards
Post #659690 25th Oct 2017 10:29pm
zsd-puma
Each wheel has a speed sensor (to tell if the wheel is spinning or locked).
Have a look behind the front left wheel, it sounds like the cable to the speed sensor is damaged, you may be able to repair the cable, if not it may need a new wheel sensor.
Post #659755 26th Oct 2017 2:14pm
Mogboy
Australia 2007 Defender 110 Puma 2.4 SW Belize Green
I also have the ABS & TC lights come on, but no fault codes (via Scan Gauge). 2007 Puma 110.
I noted excess wear on the inside pad of FL caliper, so pushed pistons back and inserted new pads. When testing brakes, as applied, immediate brake chatter and dash lights came on. Chatter stopped when lights came on. No blown fuses. Are there any relays I should check? And which one(s) if any?
Is it likely the sensor failed at the same time as brakes applied? How do I test it?
As there was signs of rusting on outside of pistons, I have since had both fronts overhauled with new pistons & seals. Still need to reactivate ABS & TC.
Post #661537 2nd Nov 2017 10:54pm
