Home > In Car Electronics > Activity Key
Tombte
Spain 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Activity Key
This nice bit of kit would be very usefull if it could be installed in our Defenders. There's a module instaled I don't know where and the wristband with it.
Do you think it's possible to fit it in the Defender with central locking or am I just dreaming about technology and Defenders?
This are the elements:
VPLRV0120 and LR091580
Post #659549 25th Oct 2017 10:50am
bankz5152
So £300+ just so you can unlock with a wristband? Seems a bit excessive!
You can install central locking onto the Defender very easily, DIY kits from Hawk cost around £30 takes about half a day to do a 90, probs need a weekend for a 110. Then you can buy a relay off ebay or Defender leccy specialists for around £15 which needs to be professionally/properly soldered onto your 10AS unit. Finally the central locking must be activated using a Nanocom.
Hey presto central locking via the original fob.
I've no idea if that unit could be tied into the Defenders 10AS alarm system but I would bet it can't without some very complicated and expensive electrical work.
Post #659555 25th Oct 2017 11:11am
JOW240725
Having watched a video last week of thieves driving off a keyless BMW by somehow just 'scanning' the front door (presumably, copying the key code signal) I'm not sure I'd want to go keyless! James
Instagram @suffolk_rovers
Post #659560 25th Oct 2017 12:31pm
zsd-puma
I'm not sure it makes much difference with a Defender being keyless or not anyway. I mean we know the doors aren't that secure and the Morris Marina ignition lock is probably still easier to bypass than the modern keyless systems!
With regards to the activity key. You can just hide the existing remote somewhere in the back of the car and lock the door with the key. The key is waterproof anyway (because it's just a key), just tie it to your arm or put it on a lanyard.
Post #659577 25th Oct 2017 2:39pm
JeremyJ
The idea of Activity Key is that you can leave the original keys in the vehicle - once locked with Activity Key they wont work (so if someone breaks in they are useless) whilst doing "activities" that may harm the normal key.
Simple answer - impossible to fit to a Defender and to be brutally honest pretty pointless (and I like toys!!)
Post #659599 25th Oct 2017 4:33pm
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
Not impossible. If you were to take the cheapo central locking kit and add a extra switching source for example a onewire RFID sensitive switch. Then place an RFID in to a watch strap then you could open the door with the wireless RFID tag.
This active looks like just a posh version.
Post #659674 25th Oct 2017 9:42pm
JeremyJ
But then how would you disable the original keys when locked with the wrist band?
Post #659675 25th Oct 2017 9:44pm
JustFX
Well the keys are inside the fortified defender as any fule wud know and they be mega hard to brake in two.
But if they manage to get into the truck and get hold of the keys then it's not good. But what the heck why not have the lock on the cubby safe also accept the RFID tag. They have been playing with the idea of RFID chips in the hand but so far people just look daft as they try and open doors.
Post #659678 25th Oct 2017 9:52pm
Tombte
It seems there are no followers to the idea of a keyless for the Defender. Maybe it's just made for the new Disco.
I'll keep doing some research, but just for curiosity.
Post #659684 25th Oct 2017 10:10pm
