Home > Off Topic > Torch for Glovebox
discomog
Torch for Glovebox
One of the essential items I keep in the Defender is a small flash light for emergency use. I've been using a Mini Maglite with a standard zenon bulb. I've now decided to replace them with a LED hand torch. There appears to be dozens on the market, so does any one have any recommendations to replace my Mini Maglites?
Please don't suggest the Evoque rechargeable as I have already ruled this out.
[/s] Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #659419 24th Oct 2017 4:20pm
rallysteve
I used to use an LED conversion for the mini-maglite, it was superb and the batteries seemed to last forever. Might be worth a try?
Post #659423 24th Oct 2017 4:29pm
My current glovebox torch of choice is the Coast HP7R, a rechargeable LED torch. I find it to be robust, extremely well-made,, versatile, and exactly right for a glovebox torch. I have also found that Coast's aftersales support is very good (one of mine got exceptionally wet on night and they replaced it FOC due to the ensuing condensation).
At the other extreme, I have just bought the latest spec Fenix RC40 rechargeable LED torch, which would (probab;y) fit in the cubby but not in a (normal) glovebox, and which whacks out an astonishing 6000 lumens. I am not aware of any other torch currently available which produces more light! It is impressive, but it is actually too powerful for many applications - it almost falls into the "weaponised" category! Rolling with laughter
Post #659424 24th Oct 2017 4:39pm
smb
You could always get hold of an OLIGHT X7R MARAUDER, but it only has 12000lumens Shocked Shocked
Post #659430 24th Oct 2017 4:55pm
Zed
I have found Exposure Lights to be excellent. Made in England too.
Post #659433 24th Oct 2017 5:14pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
LED Lenser T7 is hard to beat
Post #659436 24th Oct 2017 5:38pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I have a couple from different torches from LED Lenser and they've all been fab, I'd definitely recommend them.
Recently a purchased a Sealey LED torch/worklight to assist with a gearbox removal whilst abroad and since then used it far more than was expecting, probably more use than the torch. USB charging is handy given that everything seems to use them now. It lives magnetised to the side of the cubby box.
https://www.amazon.co.uk/Sealey-LED3601G-R...sealey+led 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #659437 24th Oct 2017 5:38pm
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
You could try these, cheaper than buying a new torch - https://www.amazon.co.uk/Maglite-Upgrade-T...pgrade+led NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #659446 24th Oct 2017 6:51pm
T140
Scotland 2007 Defender 90 Td5 HT Zambezi Silver
+1 for led lenser, i have 3 and cant fault them. nobody is perfect but being Scottish is a start
Post #659449 24th Oct 2017 7:16pm
LR90XS2011
+ 1 led lenser DEFENDER 90 TDCI XS,
Post #659451 24th Oct 2017 7:32pm
NickBristol
I’ve got 5 or 6 of these and really rate them. Cheap, very reliable and really good at lighting up the darkness, especially with some decent batteries. The battery life is excellent too.
https://www.amazon.co.uk/Adjustable-Zoomab...B005FEGYCO
Post #659454 24th Oct 2017 7:47pm
MartinK
+1... I have a Mini Maglite (2 x AA batteries), put a pair of Duracell rechargeables and a LED (120 Lumen IIRC) conversion - works great!
I also have a Led Lenser (same size) - also works great (~130 lumens IIRC)
Could not tell you which I prefer.,..probably the on/off button on the heel of the LED Lenser gives it slightly more "marks".
Both good tho Smile Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #659472 24th Oct 2017 8:26pm
Darcy Fairfax
England 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
How much do you want to spend? Question
Post #659476 24th Oct 2017 8:40pm
JAY BOY
Wales
Whistle Whistle Whistle
Post #659477 24th Oct 2017 8:41pm
ericvv
Genuine Land Rover LED mini Maglite with 67YRS inscription. Whistle
Eric
With former FCX leather handgrip
With current Adventure edition handgrip
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #659520 25th Oct 2017 5:58am
