Home > Tdi > Drivetrain slop checklist?
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Before i start messing around, is there a check list that I can go through for drive-train slop?
It's not too bad at the moment but i'd rather get ontop of it now. 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #657528 16th Oct 2017 8:08am
yostumpy
I'd start by checking / replacing the uj's (all 4 of then),and then the spline end caps for the driveshafts, go for the hD ones with the octagonal screw on caps (COPPERGREASE!!)
Post #658140 18th Oct 2017 4:45pm
Kit
It had a new propshaft a while back but i'm not sure if everything was replaced 1993 200 Tdi 90 CSW
Post #658143 18th Oct 2017 5:07pm
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
Rear radius arm bushes, front radius arm bushes [ torque steer when excessive wear] lastly A frame bushes, the ball joint is usually a big clunk when worn , Cool
Post #658278 18th Oct 2017 10:23pm
Hendrix
England 2013 Defender 110 Puma 2.2 USW Santorini Black
Mine was rear diff play which lead to eating drive flanges so definitely worth tracking down cause.
Post #658350 19th Oct 2017 12:33pm
MGCarr
United Kingdom 1997 Defender 90 300 Tdi PU Rioja Red
+1 for the ball joint on the A frame, I replaced mine a couple of weeks ago, it did not feel badly worn when levered with a big bar, only about 1mm of play but a new Lemforder OE spec ball joint has completely transformed the feel of the whole drive train. Probably the most effective £30 I have ever spent on a Land Rover.
Post #658394 19th Oct 2017 4:30pm
