![]() | Home > Maintenance & Modifications > To monitor engine or transfer case oil temperature? |
Why not contact Brian at Madman as he is based in Krugersdorp in the north of South Africa.
He is local to you and used to your local environment...If you need his phone number drop me a PM Brendan |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 675 ![]() ![]() |
Personally, I’d go for engine oil temp.
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
I think the larger lt230 sump can be had with a port for a temperature sensor,if you don’t have one already! They don’t fit Puma,s
Bows Member Since: 07 May 2012 Location: Wales Posts: 524 ![]() ![]() ![]() |
Arbel Electronics do some fantastic temperature monitoring kit. They're an uk company and design and manufacture their own products. 2006 TD5110 station wagon
1995 300Tdi 90 truck cab 1989 90 hard top with 200 tdi 1983 110 hard top 1983 110 Hi cap 1954 107 pick up |
Freddie Member Since: 21 May 2014 Location: Cape Town Posts: 46 ![]() ![]() ![]() |
Hi all,
Thanks for getting back to me. I've just got off the phone with Madmad Soth Africa, who were incredibly helpful. The Oil Temperature Sender included with the Kit is intended for the transfer box. It is to be located in place of the huge blanking plug on the passenger side of the LT230. The idea is that with EGT and coolant temperature readings, you have a pretty good idea of what is going on with the engine, without needing to measure Engine oil temp as well. However, it is possible to monitor the engine oil temperature, but you'd have to do so through the sump /sump plug as one needs 'moving oil' to get an accurate reading. As a side note. It is also possible to have multiple temperature sensors wired to a physical 'on/on' switch that can be manually toggled between in the cab of the vehicle. I battled to find any info on this - so I hope that this helps ![]() |
Thank you! |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
Freddie, I've had a Madman in my Puma since I bought it new in 2010.
On their recommendation, it was setup to monitor: EGT Engine oil pressure Coolant Temp Transfer box Temp Oil pressure is more important that oil temperature, so make sure you set the alarm at 1.0 bar - that will give you enough warning should there be a sudden oil leak. Warning levels: Coolant at 95C, transfer box at 110C, and EGT at 550C I also recommend that you do a decat, EGR blank, and fit a bigger intercooler if you have the money. And for Xmas, get a remap - BAS or Alive ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
