Home > Technical > Remove All radius arms, panhard and A frame
Page 2 of 2 <12
sako243
It doesn't take that much force to get the bushes back in if you've got them out.
You could probably use a bottle jack underneath a suitable vehicle (obviously not the one with suspension in pieces) to push them back in.
I built a press, it does have a 25t bottle jack in it but the Genuine bushes went in very smoothly with very little effort from the press (no idea how much it actually used). Getting them out is another ball game though, but I found it easier to cut through the metal with a hack-saw and then split them with a screw driver and big hammer. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #658109 18th Oct 2017 2:22pm
Frostyboy
Good idea I have a small 3 ton bottle jack maybe try it under the chassis see if it works or go for some poly bushes.
Really wish i had left the original ones in now although they must have been shot after 25 years but they looked good.
Post #658241 18th Oct 2017 9:00pm
Post #658274 18th Oct 2017 10:15pm
pannawonica
Australia
Sykes pickavant kit would make short work of those bushes. Don’t know how I could get that one past the CFO Big Cry
Post #658289 19th Oct 2017 2:34am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Just for info - with 20t hydraulic press it was only once up to 6t. The rest was less. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #658311 19th Oct 2017 7:52am
Don't let her find out!
Post #658318 19th Oct 2017 8:56am
MartnH
Australia
I actually did this.
I replaced Radius arms, panhard rod, trailing arms and A frame all at the same time.
just make sure you park your defender on a perectly flat ground. the truck is not moxving anywhere. chock all 4 wheels.
Post #678132 13th Jan 2018 2:26pm
rustandoil
Lots of things on the Sykes Pickavant website are very tempting Laughing
Post #678224 13th Jan 2018 8:02pm
agentmulder
Kuwait
I did this all on slight (slight) incline and the rod ends moved a wee bit out of alignment with the rear axle, nothing a ratchet strap couldn't pull back in to place though Thumbs Up Solved the bowel problem, working on the consonants...
Post #678228 13th Jan 2018 8:28pm
Page 2 of 2 <12
