Home > Maintenance & Modifications > Battery charger
Page 2 of 2 <12
discomog
I have both Optimate and Ctek, both work fine and have given excellent service. if I had to buy another then I would go for the Ctek. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #658105 18th Oct 2017 1:57pm
I use a couple of CTEK MXS-5 chargers for the smaller vehicles (Defender, Disco, etc) and a CTEK MXS-25 for the larger vehicles.
I have never had a single regret about this choice, they are not cheap, but they are really, really, hard to beat.
The only problem I have had with these (and other, for that matter) smart chargers is that if you have a totally flat AGM (absorbent glass mat) battery of the type typically found on ATVs and motorbikes the smart charger won't charge it, I think the charger cannot detect that the battery is there at all. For these, I usually give them a blast on my old and totally-non-smart charger, and as soon as they have some life the CTEK will then charge them in the usual way. Something to do with the characteristics of AGM batteries I believe.
Post #658112 18th Oct 2017 2:33pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
I have a Noco genius g7200, and so far it’s been very good, especially at recovering dead batteries. Does maintenance too.
Was a lot more cost effective when I bought one last year, now seems to have jumped by about £25.
Cheers, Steve
Post #658135 18th Oct 2017 4:15pm
Coatesyyy
+1 Airflow
Post #658136 18th Oct 2017 4:17pm
smb
Ive gone through about a dozen different types over the years, but since buying a ctek mxs-10 and then adding a mxs-25 they're the only make I will get from now on although I don't expect to have to replace them. Plus Martin(forum owner) offers some handy little accessories for the ctek too. As BW states, they're not cheap, but they're a lot less than all the others Ive wasted money on and they manage to revitalise a dead battery in a fraction of the time that some of the more expensive commercial chargers take. Thumbs Up CTEK all the way Thumbs Up
Post #658139 18th Oct 2017 4:39pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
Do ctek, do a 6v 12v combined charger
Post #658145 18th Oct 2017 5:12pm
Swine&Small
What are theses accessories and where are they published ?
Thanks
Swine 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #658150 18th Oct 2017 5:43pm
Martin
Site Admin
Site shop: https://www.disco3.co.uk/shop/tow-electric...c-p45.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #658176 18th Oct 2017 7:07pm
Swine&Small
Thanks Martin
2012 VW T5 Camper
Post #658269 18th Oct 2017 9:52pm
Pickles
I have a MXS5. How would I use it to charge the battery on our '13 90?
I mean, do I remove seat base & then connect to battery terminals,..would this do damage, do i disconnect battery,..then what do I have to do with respect to reconnection, or do you guys have a charge point somewhere on your vehicle,..presumably this has some sort of lead permanently connected to the battery, and if this is used when charging (I think I've asked this before), does the seat box cover have to be up for ventilation etc?
Pickles.
Post #658273 18th Oct 2017 10:04pm
Swine&Small
Hi Pickles. I have had an auxiliary 12 volt power point. (cigarette lighter type) added to my dash to power a sat nav/ dash cam,and this is a live feed not connected via the ignition so I connect my Ctek via this.
Hope this helps
2012 VW T5 Camper
Post #658288 19th Oct 2017 2:18am
ericvv
Pickles.
Pickles, did you forget about your old thread? Laughing
http://www.defender2.net/forum/topic26067.html?highlight=ctek+12s
All answers to your question are in there. If I remember well from your pictures, your truck is either garaged or under a covered carport at your house, so think easiest is to ask your dealer to install the 12S electrics to your truck and then order the Ctek adapter from Martin. You can then very easily top up or maintain your battery without even having to open your truck, same as I do. Full details also in below topic.
http://www.defender2.net/forum/topic20342.html?highlight=ctek
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #658291 19th Oct 2017 3:53am
Screbble
Really helpful thread chaps Thumbs Up
As my second optimate is now going to be buried in the garden next to the hamsters, I feel it is time to take the plunge and purchase a CTEK Thumbs Up
Lots of good feedback about these beyond the forum also.
Cheers,
Will
Post #658870 22nd Oct 2017 8:41am
zsd-puma
I've found that with totally flat batteries in general. The old style brute force chargers seem capable of reviving some completely dead batteries that the various smart chargers can't. I think the smart chargers work by measuring the battery voltage and use that to decided how much power to pump out, if they can't see a voltage they assume there's no battery there. Probably doesn't do the battery much good doing that in the long term, but it can get you out of trouble in the short term.
Post #658948 22nd Oct 2017 4:27pm
JWL
I've managed to rejuvinate flat batteries by putting some jump leads across a decent battery then charging them both together. My el cheapo Aldi special has done well using this method Thumbs Up
Post #659006 22nd Oct 2017 7:58pm
Page 2 of 2 <12
