Home > Maintenance & Modifications > Series body with modern chassis?
UtilityTruck
Has anyone on here built a retro-modern Series?
A classic series 2/3 shell onto a modern coil sprung chassis is what I'm thinking of, maybe with a TD5 or TDCI or even a V8.
I love the classic look of the early LRs and the idea of a modern coil sprung chassis appeals. Not sure if wheel offset would be a problem, clearly fitting plastic over arches would spoil the look.
If someone has a build thread or info I'd be really interested to read about such a project. I'm not in a position to start such a project myself at the moment.. but perhaps one day! 2014 Keswick Utility 2.2
Post #658027 18th Oct 2017 8:36am
Stacey007
When our children were little and up very very early...
I used to watch an American custom car program where they did crazy things (you needed to leave your cheque book)
They would take for example the equivalent of a Evoke take the body off it modify the chassis and steering etc etc and drop the series shell on top and attach. Obviously they did American cars but results were amazing.
Custom Rides or something similar, lots of celebrities had stuff done.
Cannot imaging the cost but everything is do-able...
Post #658029 18th Oct 2017 8:48am
Land-Rover themselves did from 1979 to 1985, generally known as the Stage One V8 !
Pretty much exactly what you describe, and good examples are now rare and desirable.
Post #658031 18th Oct 2017 8:51am
rallysteve
There are plenty around, most illegally registered with the Series 2/3 numberplate to claim tax exemption despite all but the body being Defender.
Post #658037 18th Oct 2017 9:21am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Nothing new there!
This has been done ever since early donor Range Rovers were cheap enough to buy and cut up!
Many of the 70s 80s trials vehicles had an early RR chassis under their bodywork, 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #658040 18th Oct 2017 9:30am
zsd-puma
Well i think the wheel arch extensions are a must if you're going coil sprung, it's why LR fitted them as the axles had to be made longer to fit the springs between the wheels and the chassis. I suppose you could possibly add metal work and make the whole body wider, but that's a lot of work!
If you just wanted the front end look, then there is a big gap between the front of the engines and the rad so it's probably not impossible to fit a modified series 3 front panel onto a Defender if you moved the rad backwards.
Quote:
Land-Rover themselves did from 1979 to 1985, generally known as the Stage One V8 ! Rolling with laughter
Wasn't the Stage 1 V8 still leaf sprung? It's basically a series 3 with a V8 and (what eventually became) the Defender Bonnet and front panel.
As someone has touched on, doing this it'll either be registered as a Defender (a modified one), or it'll have to go through an SVA to get a Q plate.
Post #658063 18th Oct 2017 10:56am
I've had many series motors on coils, used to be quite the 'norm'.
Post #658067 18th Oct 2017 11:24am
Yes, I was hoping to be able to edit my post to correct my gaff before anyone noticed, but you were too quick! Embarassed
Stage One V8 was indeed leaf srpung.
Post #658078 18th Oct 2017 12:25pm
Super7
United Kingdom 1999 Defender 90 Td5 CSW Rutland Red
How about a Series 1 body on a Defender chassis:
https://www.lro.com/reviews/featured-vehic...s%E2%80%A6
Very Happy '99 TD5 Defender 90
'52 Series 1 80"
'99 Caterham 7
Post #658130 18th Oct 2017 3:49pm
Coatesyyy
^ I like!! Thumbs Up Mr. Green
Post #658131 18th Oct 2017 3:52pm
DSC-off
This is exactly what Landrover did in 1983 when they created the 110, how much more retro do you want to be? Laughing
A tidy series model does look great though.
I suspect the wheel arches will be the biggest problem getting the 'look' right. Wider axles will need the tyres covering somehow, then the profile will not be exactly in line with wheels due to the wheelbase differences.
Depending on the engine/gearbox used fitting it behind the recessed grill may not be straight forward.
Fixing a series windscreen, roof and doors on a defender bulkhead and body tub should be relatively easy. Then just paint it an old original colour. That would get you 80% to where you want to be without too much work.
Post #658167 18th Oct 2017 6:36pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
As has been said, many people have been there and done that, mostly using Range Rover chassis cut down to suit the length of the body because Range Rover rolling chassis were cheap.
One way to avoid the arch extensions is to widen the body, difficult to get it just right so the dimensions don't look odd but, again, it has been done. Widen the bulkhead by 4-6 inches by adding a section in the middle, same with the bonnet, roof and rear bulkhead and replace the rear floor. This also has the advantage of giving you a bit more elbow room inside.
The advent of the tax exempt vehicle coupled with 90s and 110s becoming more accessible kind of killed off most of the hybrids. Before tax exemption nobody really cared if you cut down a RR chassis and stuck it under your Series I/II/III but after tax exemption it suddenly became a big issue and vehicles that had been running around for 10 years plus without an issue suddenly became a "problem" in the eyes of the DVLA.
This was mine, when I was a lot younger, using a chassis from a Range Rover that had been rolled and written off as a result, the rolling chassis complete with engine and gearbox cost me £150 at the time and it took about 6 months to rebuild my Series III as a V8 auto hybrid that won the club trials league a number of times.
Rather than replacing the chassis, there was also the option of converting the existing chassis to coil springs, as was done on this lightweight that we competed in for several years... i believe this is still being used in competition though no idea how much of the original is left !
 http://www.yorkshireoffroadclub.net/
Post #658344 19th Oct 2017 12:08pm
JOW240725
Sounds a great project! James
Instagram @suffolk_rovers
Post #658362 19th Oct 2017 1:09pm
zsd-puma
I think it was also around the same time when cut and shuts were becoming more prominent in the media, but of course they'd been around for decades. I'm sure most hybrids were done to a high standard, but i expect a few had poor welding and the legislation didn't differentiate between a Land-Rover Hybrid and two smashed up Ford Escorts welded together. So there was a bit of a clamp down on the rules to make it look like efforts were being made to tackle cut and shuts.
Post #658397 19th Oct 2017 4:55pm
UtilityTruck
Thanks for the replies and pics, @davew £150!!
Regarding track width differences and the width of the series body, does anyone know the difference in axle width(flange to flange) between say a defender and series 2/3?
I am wondering if the difference is close enough that It would simply represent a more aggressive wheel offset, or if in effect 50% of the wheel would be outside the arch after the conversion. 2014 Keswick Utility 2.2
Post #658584 20th Oct 2017 3:50pm
