Home > Puma (Tdci) > A little bit of unleaded in a 2.2 puma tank.
Dobby
So.. there I was at the garage, idly filling up the tank. A little distracted by something, I suddenly realised I was putting unleaded in the tank instead of Diesel. About 7.27 Litres to be exact.
A few thoughts crossed my mind just then, but the decision I made was to holster the unleaded pump and fill up with Diesel to a full tank, including the pipe. So I've got a full tank of Diesel with about 7 litres of unleaded, that must be about 8-9% I guess.
I'd heard that people often put a drop of unleaded in the tank at MOT time if the emissions are bad, as it makes for a cleaner burn, so I decided that I'd be ok. Anyway, I gingerly started the engine (all of so far) and drove the 6 miles home. As far as I can tell everything seems to be ok. A little perkier if anything, certainly smoother, but I'd expect that.
The question is, will I be ok to run the engine with the 8ish% unleaded mix? I hope so
Wondering what the collective wisdom is here.
VMTIA
Dobbs (aka the muppet).
Post #657668 16th Oct 2017 7:29pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I can't see that amount would cause an issue?
If it was me, I would run it down to 3/4 full then fill up with diesel again, and then keep topping it up. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #657673 16th Oct 2017 7:35pm
Siwynne
My Mrs put £20 in an empty disco4. I put another £60 on top and we didn't experience any issues. No dpf though
Post #657678 16th Oct 2017 7:40pm
ickle
did the same in my 2.4, kept topping it up - no issues at all.
good luck
Post #657681 16th Oct 2017 7:47pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
I did the same on my Range Rover L322 1/2 filled nearly £50 worth of petrol just filled the tank to the brim with super diesel or what ever they call it .
Post #657684 16th Oct 2017 7:51pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
I might risk it in my old 200TDi but not in a 2.2 with a high pressure fuel system.
Post #657690 16th Oct 2017 7:58pm
Dobby
Yeah it was the DPF I was worried about, tbh.
Post #657695 16th Oct 2017 8:03pm
Fill the tank right up with diesel now and you'll lesten any effect of any issue.
That should be fine. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #657713 16th Oct 2017 8:17pm
ian series 1
DPF will be fine, seen it done plenty of times. 80" 80" 86" 88" 90"
Post #657714 16th Oct 2017 8:19pm
Dobby
All sounds encouraging, thanks chaos.
If someting does go bang, i'll let you know. Apart from the usual suck, squeeze, bang, blow.
Very Happy
Post #657727 16th Oct 2017 8:39pm
pannawonica
Australia
I would have been inclined too chuck least half a litre of 2/C oil into the mix asap! Thumbs Up
Post #657778 17th Oct 2017 1:46am
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Cold countries run petrol in diesel to stop waxing. Up to 50%.
Post #657779 17th Oct 2017 4:13am
AMBxx
Am I the only driver on here who has never filled up with the wrong fuel?
Just need to be extra careful next time I fill up - pride comes before a fall! Big Cry
Post #657804 17th Oct 2017 8:57am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
"Am I the only driver on here who has never filled up with the wrong fuel? "
No, I have never managed to do it, but S.H.M.B.O. did it to both the Disco which was petrol and her 90 which was diesel within 30 minutes of each other. The recovery driver and the Indy tried so hard to keep their faces straight in front of her. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #657809 17th Oct 2017 9:44am
Dobby
Really? That'll help too. Lube the pump I guess?
Post #657842 17th Oct 2017 12:59pm
