Home > Td5 > Instrument panel bulbs ( FIXED)
Page 2 of 2 <12
dorsetsmith
good luck
Post #655451 6th Oct 2017 7:08pm
Djcla
Well I can't see anything on my switch to connect cable to , so thinking I'll just get the right switch.
Post #655843 8th Oct 2017 4:24pm
dorsetsmith
A lot easier to replace this than tracing wiring problem
Post #655861 8th Oct 2017 4:59pm
Djcla
dorsetsmith wrote:
http://www.allbrit.de/UNI.cfm?PAGE=756390&SPRACHE=EN
switch is fitted to head brake ( item 2 )
Land rover parts are telling me part EEP191L is LHD only does that sound right ?
Also tying to understand how this actually works , ie hwo is the witch activated / depressed
Post #656002 9th Oct 2017 8:43am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
When properly installed the black square plunger is what activates the circuit. With the hand brake lever in the up position (transmission brake engaged) it works by closing the circuit (the plunger is out). When the the hand brake is in the down position it opens the ciruit and the light goes goes out (plunger is in). 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #656083 9th Oct 2017 3:55pm
Djcla
new part arrived and fitted and now working as expected , just need to find the plastic nails now to hold the gator in place
Post #656751 12th Oct 2017 12:24pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Let me know when you find the part number - I could do with a fresh set of those Smile
Post #656801 12th Oct 2017 3:38pm
Djcla
AFU1897LDE , I'll buy a pack of 10 at some point soon, can just post a few up to you then if u like
Post #656851 12th Oct 2017 7:36pm
Intercept
That's very kind - thank you, but I need the black versions, which I've now found here
Post #657035 13th Oct 2017 12:50pm
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
not yet fixed..
OK bit of a novice; my handbrake light ceased a while go, (only thought about it after I tried to drive one day...)
I moved rubber gaiter aside & put a meter on the single wire, with ignition on it reads 10.7V on a few earth points. No idea why, to check my metering the battery read 12.1.
I kjnda assume that if it's got 11V or so, then the dash light should come on when earthed?? It doesn't.
Does this prove the dash light is faulty?
Thanks experts. Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #909283 24th Jun 2021 1:50pm
Page 2 of 2 <12
