Home > In Car Electronics > Can't Get Carling II Switch Red Light On!
bankz5152
Wired up my dash (with help) over the weekend but I can't for the life of me get the red 'on' LED to come on! Tried a few things but wiring is not my greatest strength!
Got two sets
On-Off-On - Heated seats
Mom - Off Mom - Leccy windows
I don't mind not having the leccy window red slit but I do want it on my heated seats.
Anyone know what to do here? Which pin to connect to what?
Thanks
Post #656285 10th Oct 2017 11:40am
Martin
Site Admin
Got a link to the switch so I can work out the pinout?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #656286 10th Oct 2017 11:42am
bankz5152
Post #656288 10th Oct 2017 11:59am
Martin
Site Admin
Table in their wiring instructions PDF gives:
1: Power Out 1
2: Power in
3: Power Out 2
7: Earth
8: Sidelight (illumination)
9: Earth
10: Link Pin 1
Pinout as viewed from bottom of switch:
8 -- 7
1 -- 4
2 -- 5
3 -- 6
10 -- 9
However, the PDF does say:
Quote:
Please note that the narrow bar on 'On-Off-On' function switches will only illuminate in one 'On' position
This is done with the pin 10 link, so if you want it on for the "power out 2", then link it to 3 instead.
You CAN make the illuminated bar work in both "On" positions, you would need to add 2 diodes to the wiring though to prevent the output circuits being electrically connected. I can supply more detail if needed.
http://www.mudstuff.co.uk/pdfs/Carling%20W...202017.pdf  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #656304 10th Oct 2017 12:37pm
bankz5152
Thank you!
They where originally wired up in my 90, which when on High the bar would be bright, when on low the bar would be dimmer. I plugged everything back in the same way but the red bar never came on again!
So to get the red light on I connect pin 10 to pin 3 or pin 1?
Post #656313 10th Oct 2017 1:06pm
Martin
Site Admin
Correct - pin 10 is the positive feed to the bar, so connect it to whichever output pin you want it to come on with Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #656333 10th Oct 2017 2:24pm
bankz5152
Smashing Cheers!! Very Happy Very Happy Very Happy I shall let you know how I get on, got to remove the head unit again to fit the DAB aerial and other bits!
Post #656334 10th Oct 2017 2:27pm
bankz5152
Thanks again!
Got the heated seat switches wired up, had an earth that was part of the seat loom, that went into Pin 10 then linked to Pin 3, Pin 9 was then earthed and hey presto! Got bright red light on when "high" and dimmer light when on low heat!
Post #656795 12th Oct 2017 2:54pm
