![]() | Home > For Sale & Wanted > [Wanted] Indicator self cancel ring |
Knocker458 Member Since: 21 Feb 2014 Location: South West Posts: 45 ![]() ![]() |
Looking for the one to fit a 02 TD5, believe it's NRC 7636.
Cheers |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
Only £7 plus VAT from most suppliers; Snap Ring Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
Appreciate that, just bought one from Totalparts costing 7.96 plus VAT PLUS 3.50 for delivery by second class royal mail which I thought was a bit steep for this very small, light piece of metal.
If you do not have the correct pliers to fit it there are some good tips out there, especially for aftermarket steering wheels, I forced the snap ring over sockets one after the other increasing in size until it just slid onto the rim o the boss. Just got to get everything, logs etc. at 6 and 12 o'clock positions Jeff Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
Notwithstanding the fact that online shops generally can't work out that little light stuff costs a bit less to post, they have to start somewhere with postage rates. They have fixed costs associated with ordering in, storing, picking and packing parts for orders which all comes under the P&P charge.
The part is an LR supplied part which you can pick up from any LR dealer parts dept (ring and order it first). Ask nicely and you'd probably get a discount too. So cheaper and no postage ![]() ![]() ![]() |
PS: if the packaged size of the part is greater than 25mm in each dimension then it would be posted as a small parcel, Royal Mail price is £2.90 2nd Class.
I can't imagine many orders fall under 25mm thick when packaged so it's probably not worth the hassle/overhead to set up the shop system and product data to work this out and charge the cheaper large letter rate for these orders. Don't blame the supplier for RM postal rates. ![]() ![]() |
Thanks Jeff for the fitting advice and Martin for the postage tips, I'll look to LR as that seems the easiest option
