Home > Maintenance & Modifications > OME shocks / Bilstein ?
Chopperone
2007 TdCi 90 chipped/bas intercooler ,18” Bowlers...
I think I am pretty settled on OME shocks for mainly road use. Minimal towing but once a fortnight I carry around 200 kg + .
OME do 3 x different grades of shock described as Light / med etc.
Which to go for OR bilstein
TIA
Guy May your life be like toilet paper ; long & useful.
Post #655549 7th Oct 2017 7:45am
williamthedog
Wouldn't use Holsteins, they might upset the handling a tad Rolling with laughter
Seriously either are ok, have you looked at konis as well?
Post #655555 7th Oct 2017 8:26am
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Neither....I'd go for Koni shocks, adjustable too. Thumbs Up
N.
Post #655556 7th Oct 2017 8:28am
Biffas
England 2014 Defender 110 Puma 2.2 USW Corris Grey
Fitted Bilstein on my 110 usw with a comfort suspension kit from a well known company and made it harder than standard so i have taken them off the rear and back to original shocks which is much better havnt had time to remove them from the front, Bilsteins are way to stiff i was very disappointed with the ride i also so fitted an uprated anti roll bar which i have removed as it was rubbing the standard fuel tank guard.
Post #655562 7th Oct 2017 8:51am
Coatesyyy
+1 for Koni shocks. Can't fault them and are fully adjustable to suit whichever set up you require Thumbs Up
Post #655565 7th Oct 2017 9:00am
geobloke
-1 for Konis not a patch on Old Man Emu IMHO.
They did not cope very well with the extra weight of the roll cage and the adjustability part is just a gimmick as you do have to remove each shock to adjust. If you do want adjustable shock absorbers then think about those that have a physical switch.
Post #655567 7th Oct 2017 9:05am
Swine&Small
Has anyone else found this to be the case? 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #655571 7th Oct 2017 9:21am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I fitted the shocks,springs and ARB as detailed and found it a softer ride, in fact S.H.M.B.O. said she thought it felt like the Disco 1 we had previously. I will have to get underneath to see if the A.R.B. is rubbing. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #655593 7th Oct 2017 11:27am
Swine&Small
Hi Richard. Yes that is what I expected to hear.
I will comment on Tuesday next after a 3 hour drive home with the new setup Thumbs Up
Brian 1983 Series 3 Pick up in Marine Blue
2012 VW T5 Camper
Post #655603 7th Oct 2017 12:14pm
Biffas
Richard be interested to see if your anti roll bar has rubbed the tank guard my did after a day so i removed it, i had a disco 1 and mine did not drive like that infact my wife said what the F"""" have u done to this she was not happy. Made my back door really rattle as the ride was so hard.
Post #655607 7th Oct 2017 12:32pm
MK
Only the rebound can be adjusted on these Koni shocks Puma 110" SW
Post #655759 8th Oct 2017 1:59am
pannawonica
Australia
[quote="geobloke"]-1 for Konis not a patch on Old Man Emu IMHO.
They did not cope very well with the extra weight of the roll cage and the adjustability part is just a gimmick as you do have to remove each shock to adjust. If you do want adjustable shock absorbers then think about those that have a physical switch.[/quote]
With shocks it's really a case of what works for you. From my prospective the original equipment lasted only too60KKm,s. whilst O.M.E (Yellow Monroe,s) do have a strong following out here Koni have a good reputation for durability and performance. Usually I give the go to OEM, but in this case went too Koni! Originals only going too 60KKm,s was a bit ordinary. My theory its probably the heat out here, two years for battery's and all!👍 Time will tell! Very Happy
Post #655763 8th Oct 2017 3:09am
DAZ110
Got Bilsteins on my 90 (it had them on when I bought it) and it has definitely made it a stiffer/harsher ride.
I’ve got some standard shocks but not yet got around to fitting them. Rolling Eyes
Post #655792 8th Oct 2017 9:53am
AJC
Recently fit OME Medium duty kit from LRS off-road.
Very happy with it
Post #655794 8th Oct 2017 10:07am
mick
I’ve had Konis fitted to the 130 with standard OEM springs with no issues and it’s loaded all the time.
Post #655801 8th Oct 2017 11:59am
