![]() | Home > Td5 > Td5 battery drain |
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
Could be a defective diode in the alternator. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
| tony.g Member Since: 25 Aug 2017 Location: uk Posts: 23 |
Thanks, I did wonder about that since speaking to others, and there seems no other area of leakage; have ordered a replacement alternator.
Cheers. |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3526
Unplug the alternator and see if the battery drain stops, before throwing another one at it.
Hi, attempted that and undid the cable with rubber cover on, but couldn't get the multiplug off the back as I don't have elastic fingers! (God knows how it's done).
But I'm going to put a new fan belt on so may as well replace the unit at the same time. I disconnect the battery overnight. (btw, if you're in Stockport, you'll probably know the crew at the shop near Nelstrop's, behind Lancashire Hill! - I'm up the road near Parrs Wood). |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
if think that's
Oh yes you mean Land Ranger Services?
Never used them though, are they OK? |
