Home > Maintenance & Modifications > Voltmeter DA7481
waz
Jersey
Voltmeter DA7481
Hello to all
My first post, hopefully someone out there might have fitted one of these & can advise what the illumination is ?
I have a 1987 V8 County & am about to commence upgrading to TD5 instruments. I'd like to replace the standard time clock with a Voltmeter & have come across this from Paddocks, DA7481
It looks in keeping with the TD5 gauges but does anyone know if it illuminates the same, green with an "Orangey" pointer ?
Thanks in advance for any replies
Waz
Post #608615 11th Mar 2017 2:08pm
rallysteve
I am afraid that is quite a different style to the td5 ones. You need to have a search for VDO vision gauges which will match 99%. Main difference is they have an orange needle whereas the OEM ones have white.
Post #608660 11th Mar 2017 5:11pm
waz
Jersey
Thanks Steve
Had seen the Vision ones & was considering replacing all the 52mm gauges with these but for the orange needle. Could do with seeing a cluster fitted with them before spending all that money, which was why I thought the Paddocks gauge would match better. Only the nightime illumination putting me off at the moment, hence this thread. Suppose I could paint the TD5 Speedo needle orange if it comes apart
Warwick
Post #608665 11th Mar 2017 5:44pm
zsd-puma
http://www.croytec.co.uk/all-products/vdo-products/volt-meter/
Or give these guys a call and describe what exactly you need.
http://www.caigauge.com/
They made guages for BL, and Rover group and are the original Smiths Industries Gauge business, and will make them to order if you describe what you need.
I've an idea they actually make the VDO gauges anyway.
Post #608702 11th Mar 2017 7:56pm
HardCharger
So will the part the original posted stated work with a Puma? Is it green back lit?
Post #654726 4th Oct 2017 5:51am
waz
Jersey
Hello
Contacted Britpart at the time, this was their reply to me so I didn't order one :
<Graham>
14 Mar
Dear Sir,
With reference to your recent enquiry. We have run a power test on the unit. It has a white illumination. The needle finger is white so assume it will glow white.
Regards
Graham
Hope this helps
Warwick
Post #654796 4th Oct 2017 11:09am
zsd-puma
Any Volt meter will work with a Puma, though you would need some form or mounting for it, such as the one that comes as part of the Double din kits.
You can change the colour of the illumination by painting the bulb with green nail varnish (or similar)
Post #654812 4th Oct 2017 11:46am
HardCharger
Thanks, waz.
Thanks, zsd-puma.
Post #655033 5th Oct 2017 2:46am
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
I used a blue sea multimeter on my puma
It dims, measures voltage and current (with a shunt)
And can set up an alarm
To mount it, I just cut a hole in the dash using some drill bits and a flat file
It's a defender anyway. Even if you don't a bad job, it still won't look too out of place
Post #655036 5th Oct 2017 5:20am
