Home > In Car Electronics > Fitting tweeters - TD5
Page 2 of 2 <12
excossack
There is a what looks like a small capacitor.
Next I need to mount them. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #508539 26th Feb 2016 9:32pm
grafty99
CDN38 wrote:
grafty99, what are you running in your lower dash for speakers?
They're 130mm edge components. Just cheap ones from halfords but they don't sound too bad. Eventually I'll do a full blown focal setup Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #508602 26th Feb 2016 11:52pm
excossack
If I did decide to fit speakers in the lower part of the dash what size holes would need to be cut? 1999 Defender TD5 110
Regards
John M0VAZ
Post #510680 4th Mar 2016 2:18pm
jimbob7
I fitted Focal tweeters,in the same place as Pumas.Think I used a 40mm hole saw for an absolute perfect fit,didn't need mastic or anything!!
Also fitted 5 1/4 inch (130mm) speakers in place of the originals (4 inch,100mm),only needed to slightly widen the original holes,(+25mm mdf speaker rings).Trim the thin foam and easily snip the 1mm metal backing with cheapo wire cutters/tin snips. Pov.spec,ftw. 2006, 110,TD5.
Post #511685 7th Mar 2016 6:20pm
excossack
Thanks JimBob7. For those Defenders without speakers (Poverty spec?) do the dashboards come marked where the speakers need to go? I.e is there a moulding mark somewhere? 1999 Defender TD5 110
Regards
John M0VAZ
Post #511776 7th Mar 2016 9:39pm
mk1collector
No Td5s had tweeters on top of the dash and there are no marks to tell you where to put them, I just spaced them equally from each end so they looked OK. Ray
My build thread
Post #511821 7th Mar 2016 11:10pm
Djcla
im interested in doing this but a little confused as to how you wire the tweeters up to a head unit can anyone explain?
Post #654357 2nd Oct 2017 3:52pm
dorsetsmith
Puma tweeters with crossovers built in wired in parallel with main speakers
Post #654362 2nd Oct 2017 4:16pm
Djcla
Ah ok so you basically piggy back onto the main speaker connection or join the wires together?
Post #654399 2nd Oct 2017 6:42pm
dorsetsmith
Yes + to + and - to -
Post #654406 2nd Oct 2017 7:07pm
Djcla
Re: Fitting tweeters - TD5
jwl wrote:
On my TD5 110 I have speakers just above the B Pillar in the headling and that's it. Now got a pair of tweeters but where to fit and how?
Do these wire in direct from the speaker feeds, so into the speaker with two wires and then two wires out into the tweeter?
They sound good what were they make/model wise?
Post #661295 1st Nov 2017 10:51pm
Page 2 of 2 <12
