![]() | Home > For Sale & Wanted > Defender XS 2015 leather steering wheel. |
Oldyellar Member Since: 04 Sep 2015 Location: Central Posts: 415 ![]() ![]() ![]() |
Do you know if this will fit 2011 defender ? Also can it be posted
TOP5N Member Since: 03 Nov 2015 Location: Gloucester Posts: 226 ![]() ![]() |
Hi. I am pretty sure it will be the same. It is a 46 spline. Could be posted. Would be about £8
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3410 ![]() ![]() |
you might need to scour the forum for more info as the steering wheel changed for the MY2015 to cater for the extra tabs for the steering wheel position sensor for the DSC stuff. Not sure if it's backwards compatible
Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 227 ![]() |
It will most likely fit the older model, though will not have to rear tabs which cancel the indicators at the switches.
You can however modify the steering wheel to suit, so long as the toothed fitting is a match. |
Thanks for provoding the info guys. Is a cheap wheel as others listed on ebay at £140 upwards.
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1893 ![]() ![]() |
Yes please TOP5N - PM me please where to send the money including P&P.
Thanks ![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
Will do. Thanks
Done
NOW SOLD.
