|  | Home > Maintenance & Modifications > steam clean(er) |
| williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441    | Too expensive really, just see if you can use somebody elses, if not give it a good pressure wash 👍 | ||
|  30th Sep 2017 8:14pm |
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720      | Just take it to a local HGV specialist, it's ony going to cost beer tokens. And it'll be a proper steam cleaner not just a jetwash. | ||
|  30th Sep 2017 11:08pm |
| Coatesyyy Member Since: 07 Sep 2017 Location: Knutsford Posts: 423    | I just used my pressure washer and gave it a very thorough cleaning! | ||
|  1st Oct 2017 1:06pm |
| ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1777    | Steam all the way. Kaarcher professional. Expensive? Yes but they are great especially in winter when you don't have to get your hands wet. Why would you attempt to wash the dishes in cold water? Hot water cleans more effectively.
   Click image to enlarge | ||
|  1st Oct 2017 4:30pm |
| pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568    | Some pressure washers can be fitted with a steam/hot water additional module. However don't think I've had the need, spray on, brush on degreaser then cold water blast. Honda GX390 power big Speck geared pump not a problem.   Must admit I thought about it, mostly it would have been sat about not earning its keep | ||
|  2nd Oct 2017 4:43am |
| Posting Rules
