Home > Technical > Exhuast gasket after turbo
jst
Is there an exhaust gasket that goes between the turbo manifold and the CAT downpipe? i think mine is whistling from there but local parts people say there isint a gasket in there, was wondering if it had blown. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #653175 27th Sep 2017 4:35pm
bankz5152
On a TD5 there is. Dont know about others Smile
Post #653179 27th Sep 2017 4:41pm
geobloke
There definitely will be a gasket between the turbo and down pipe. Thing to listen out for is the flexi joint just below the union can also wear and spring a leak. It should be noticeable by black soot around the area it is escaping from.
Post #653182 27th Sep 2017 4:51pm
jst
thank you, does anyone have a part number, mine doesnt have one fitted! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #653200 27th Sep 2017 6:24pm
geobloke
I think it is the same as the TD5... something like esr3737
Post #653206 27th Sep 2017 6:38pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
I've just had my exhaust off my 2010 and not found a gasket. Didn't leak though. Might be worth cleaning up the mating surfaces and torquing it back up.
Post #653233 27th Sep 2017 8:12pm
jst
well i dont think there is one there from digging i have done but i seem to remember an aftermarket gasket being thicker which i think was to go here but not sure. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #653247 27th Sep 2017 9:13pm
jst
its a 4 hole bolt design Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #653248 27th Sep 2017 9:15pm
jst
http://www.ebay.co.uk/itm/EXHAUST-PIPE-FRO...SwWTRWuKFe
^^ maybe? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #653250 27th Sep 2017 9:17pm
jst
http://www.defender2.net/forum/post360508.html
this is the post i was refering to, so this relates to another gasket i take it as ref to a 3 hole Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #653251 27th Sep 2017 9:20pm
jst
I am getting a bit of squealing from engine area which i assumed was the mating of the down pipe to the 4 bolt exhaust/turbo manifold. thoughts please? Its under load. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #653255 27th Sep 2017 9:26pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
Hi james what truck is it on, sounds like the td5 exhaust manifold warped, similar to when you whistle a blade of grass between your fingers?!?..
Check for soot around manifold/studs..
Cheers Alex 98 300 tdi 90 project
88 200tdi project soft top
96 disco 1 jap import
79 911 sc
08 130 double cab utility
Post #653279 27th Sep 2017 10:31pm
geobloke
Rolling Eyes
Post #653308 28th Sep 2017 6:10am
jst
its a brand new downpipe. the old one didnt have a gasket in there, there isint one there currently, its whistling and i wondered if there is meant to be a gasket in there and what MPN it is if there is one
2007 tdci 2.4 Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #653318 28th Sep 2017 7:14am
pannawonica
Australia
When I put my 2011 110 2.4 puma on the hoist I thought I'd lost the gasket on fitting the decat pipe on to the turbo. So rang the dealer parts department in panic, and was told there was not one. Thumbs Up
Post #653349 28th Sep 2017 10:43am
