Home > Technical > EGR blanking
jst
EGR blanking
does it matter which end of the cooler you blank an EGR off?
EGR valve end seems most suggested but other ends looks easier to get to? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #652717 25th Sep 2017 6:34pm
It should be inlet side really. Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #652721 25th Sep 2017 6:46pm
jst
that was the plan, but does it matter which end of the cooler? drivers side seems more accessible rather than taking the valve off Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #652722 25th Sep 2017 6:48pm
I've only heard of fitting EGR end, and is this way on mine. Recommended by Alive.)
You should be able to slip the blank in from the side and only loosen the bolts.
The tricky bit is getting the bolts back in and the gasket once removed completely.
But you won't have that, as most blanks you can slip in from the side.
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #652724 25th Sep 2017 6:57pm
jst
thank you Steve, so on that picture it goes next to the cooler rather than on the flexi down pipe fitting?
Out of interest how many miles on that vehicle - looks chocked! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #652730 25th Sep 2017 7:25pm
Yes, cooler side. Gasses are from exhaust manifold through cooler, through egr exiting the flexipipe. Mileage that was only around 36k (I can't quite remember) I'm on just turned 60k now. I replaced the EGR for brand new and it went under not 6 months later again. Since I also now run Millers diesel additive too. You'd be surprised how dirty they get _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #652737 25th Sep 2017 7:49pm
jst
i have some EGR faults and this vehicle is on 60ish K so time to blank i think, thank you, hopefully plates are in tomorrow. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #652757 25th Sep 2017 8:41pm
Let's us know how you get on. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #652774 25th Sep 2017 9:15pm
jst
Access not actually that bad, all loosened valve end of cooler, just waiting on parts Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #652914 26th Sep 2017 12:58pm
