Home > Maintenance & Modifications > How do you do the steering damper nut up?
alastaid
Hi,
Getting round to bolting on my Peterborough bits, one of them is the Bilstein steering damper. So unlike suspension dampers it doesn't have the little tab bit on the end that you can hold to stop the thread spinning. It comes with a new nyloc, so there is no chance of doing it up as is. With all my strength I managed to compress the damper and get the eye bolt through, do I have to take this off again, let the damper extend and is there some flat or something on the shaft
that you can use to stop it spinning?
Thanks
Alastair
Post #652343 23rd Sep 2017 9:04pm
You could try using the end of a small adjustable spanner on the thread tip. I thought when I did mine you could hold the body of the damper on genuine ones which maybe different to those. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #652362 23rd Sep 2017 10:31pm
williamthedog
Impact wrench easiest, if you haven't got one wrap a rag around the damper and hold it with a pair of stilsons. It will stop it spinning. Thumbs Up
Post #652382 24th Sep 2017 7:28am
gilarion
You are having difficulty because you are fitting it the wrong way. At least not the way I was shown how to fit one.
I have always fitted the damper the other way round first insert long thread then hold the damper with a griper glove and tighten up the nut once the nut starts to bite it is easy to fully tighten, then pull the damper until you can locate the hole end over the bolt bracket, place in the bolt tighten nut job done. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #652411 24th Sep 2017 1:01pm
alastaid
Right, for anyone else doing this, there is a hex key at the end of the thread, so put an allen key in, and do it up, bobs your uncle. Wish I had bothered to look earlier!
Thanks all
Alastair
Post #652498 24th Sep 2017 9:40pm
miker
Now put a blob of grease in that hex hole and something on the threads, so that when you come to remove it you just have to wipe it out, and not deal with a rusty road griney mess!
Post #652560 25th Sep 2017 8:22am
