![]() | Home > In Car Electronics > Philips Racing Vision Bulbs 150% better ? |
| legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004
You should read some of the indepth posts on here regarding these bulbs ,I not sayin if they are right or wrong but has put me off them also my daughter bought some bulbs from Halfords which one just blew up one night,she has never told me this until I was talking to my son in law again off putting.
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
After running Speaker EVO for 3 years, I went back to my genuine Cristal headlights with uprated H4 halogen bulbs from Land Rover. That was now about 2 years ago in 2015, and they still doing well.
Light output is much better than a standard H4 bulb, it says +100% on the package, bulbs are filled with Xenon gas, but they actually remain just crispy white fully road legal H4 bulbs. I don't know exactly which make it is that Land Rover source, but the part number is VPLDV0061. Link to the part is below. Eric http://gear.landrover.com/gb/en/defender/e...grade-kit/ You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5376
From what I have found in the past with my rover metro, you can change the bulbs as many times as you like, but if the lens them selves have seen better days then you are
If you are looking at changing the bulbs then why not just fresh the lens to go with it, I did that with my dads rather than him fork out for new bulbs, I did the same with mine and went crystal. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Well I started off asking if Philips Racing Vision Bulbs really where 150% better and ended up buying some Speaker Evo 1 8600 LED headlights which thanks to leeds who pointed out the pitfalls of non E marked lights.I will soon see myself I hope.
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21033
You won't go wrong with those great upgrade. I have a Noldens and have been impressed.
Crystals with upgrade bulbs are a great upgrade for the value, an excellent pre cursor mod to going LED at a later date if on a budget. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| deejayen Member Since: 18 Sep 2017 Location: Inverness Posts: 56
What are the upgraded headlight wiring looms? (I have a 2004 Defender 90 TD5)
A web search brings up "Boomslang" looms - is that the sort of thing? Also, what do they do, and how difficult are they to install? Do they supply a higher voltage to the halogen lamps, making them run brighter/whiter, but with a shorter life? |
| kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1324
The boomslag loom is an example. You can make one up yourself.
It does not provide higher voltage - what it does is it removes the current from going via the switch (the stalk switch) to the lights as this sometimes burns out the switch. So what the loom does is connect the switch to a relay. Switch works the relay which then provides power to the lights. You have to connect the relay to the battery or alternator |
That sounds useful - I've burnt through a handful of main switches over the years!
From some comments I got the impression that they'd make the lights brighter, but perhaps I'm getting it mixed up with some other changes. |
Voltage is increased by lower resistance and lowered voltage losses. And as suggested power fed directly from the alternator and not through to OE switch.
Voltage is still regulated and with in range of suitable use. I run a Land Reiziger loom despite running LEDS that are voltage regulated. Although current draw is relatively low, it still brings current flow through standard switching down to mA. Milliamperes level. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| All times are GMT |
