Home > Td5 > 10P vs 15P engine block
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Anybody know if there is a difference between the 10P and 15P block? I know the heads are different, injectors, ECU etc. But if you were going to replace the block on a 10P engine, could you use a 15P block? it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #651594 20th Sep 2017 7:47pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
A number of sites list part LBB111690 as 1999-2006 as the superseded final part number, so presumably they should be backwards compatible?
Post #651613 20th Sep 2017 8:10pm
CDN38
Did some poking around in the the JLR Electronics Parts catalogue and learned the following:
Over the entire Td5 build period, there is only 1 part number for the bare block. ERR6977
That tells me they must be the same for all years, 10P, 15P and 16P.
Looks like the block remained the same, and a 10P head would fit a 15P block. it's a Landrover thing...
Post #651673 21st Sep 2017 4:03am
dorsetsmith
you also need new camshaft for 15P head , FPR too
Post #651688 21st Sep 2017 8:24am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
CDN38 you rebuilding your motor?? Something catastophic happen? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #651802 21st Sep 2017 1:53pm
CDN38
LOL... no I'm all good.I've had a new head on mine now for a few months, just tired 150,000km on the weekend.
Just helping out a friend of mine with a restoration project. The short engine (short block to us westerners, just a block with pistons and crank) came with a 15P serial number. The original was a 10P but it also had a new (well, 10,000km old) AMC head on it. Just wanted to double check everything was good before putting it together. it's a Landrover thing...
Post #651830 21st Sep 2017 3:35pm
4RF RDS
Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #651961 22nd Sep 2017 12:10am
