Home > Puma (Tdci) > 2.4 2007 Rough idle worse in cold weather
Page 2 of 3 <123>
jst
i was told today by an independent that you can just fit a new VCV and leave it be, doesn't have to be 'learned' its better if it is but not essential.
The pressure relief valve on the fuel rail LR006866 i believe, seems to be quite a bit ££££, is there a ford equivalent part does anyone know? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #650648 16th Sep 2017 4:31pm
jst
LR one http://www.brit-car.co.uk/product.php/2214...ure_relief
Transit one http://www.ebay.co.uk/itm/251563342126
Both for 2.4s would they be the same...? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #650649 16th Sep 2017 4:38pm
M94PUMA
It's not essential but highly recommended to get it re learned and pilot corrected
Post #650654 16th Sep 2017 4:50pm
jst
well i was going to do the whole job and get a relearn, but when i phoned for a price for the learn i was told it didnt need it hence the post.
Whose fitted one and not done a relearn? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #650658 16th Sep 2017 5:09pm
It will run without a relearn, and if the old VCV was faulty it will run better with a new one. Given time it will relearn by itself, but the higher the mileage the longer it takes.
Post #650666 16th Sep 2017 5:45pm
jst
ok, thank you, so may well be fitting the one i have here and not doing the relearn. if it runs better i know the old was faulty and can then either pay to match it or let it sort itself out. thank you. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #650692 16th Sep 2017 8:18pm
Bluest
o4dn wrote:
I've found out in the release notes for the new version, I've been waiting for ages for this feature to be added Smile
The Nanocom forum also has some discussion about that feature and where it was added (was not obvious at first in which menu entry it was to be found...)
Nanocom forum is here: http://forum.nanocom-diagnostics.com/
You can get the SW update from the restricted area:
https://www.nanocom-diagnostics.com/restricted
Additional information (and how to upgrade) can be found either on their forum or in the documentation (including videos)
Damnation! Just discovered I need a Windows PC to do the upgrade, I've got an old Mac. Need to find someone with a PC I can use. 2007 110 TDCi Station Wagon XS
Post #651075 18th Sep 2017 6:58pm
jst
I have gained access to a code reader and am repeatedly seeing p0404, p0100 and p1103. EgrFault causing the maf problems or both at fault? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #651339 19th Sep 2017 5:35pm
EGR causing MAF readings to be thrown out most likely.
Likely culprits is EGR only. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #651343 19th Sep 2017 6:05pm
jst
cheers, so will that cause the rough cold idle too?
solution is change the egr/clean it or could it be mapped out and blanked? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #651381 19th Sep 2017 8:38pm
schuee
I was experiencing exact same symptoms, rough idle and kangaroo juice thrown in when cold weather which cleared after engine warmed up, I had VCV replaced and pump and injector pilot relearn carried out and this cured the problem 100% Very Happy Not saying it may cure your symptons, though from memory VCV replacement was not that expensive.
Keith MY2011 110 XS USW
Post #651515 20th Sep 2017 2:07pm
jst
thank you
have a consistent EGR fault currently so am going to sort that then if persists looks at VCV change. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #651524 20th Sep 2017 3:18pm
EGR issues can pose similar issues as the VCV.
The symptoms Keith describes above were the same for me when I had EGR stuck closed issues.
I myself went for an Alive stage 1 EGR shut down and blanked.
In fact my EGR there now is faulty but shut right off.
I bought a new EGR to replace and packed up 6 months later £160 down plus my own Labour. Rolling Eyes
Cleaning them seems very hit and miss, I never tried as I didn't think it would be reliable anyway. ____\We|Will|Win/___
Post #651527 20th Sep 2017 3:35pm
jst
i am probably going for the Alive software off for the EGR and be done with it. Did you blank yours too? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #651564 20th Sep 2017 6:22pm
I did indeed, to be on the safe side.
You can slip it in from the side and torque figures are somewhere in my gallery or on here. ____\We|Will|Win/___
Post #651569 20th Sep 2017 6:31pm
Page 2 of 3 <123>
