Home > My Defender > My new 200tdi hardtop 'project'
Page 4 of 4 <1234
CarMan
I feel as if I am at a bit of a crossroads!
Love the patina, but much less so the dented panels.
So, thinking seriously about:
new bonnet - existing not rusty at all but dented
new rear hard top side panels - badly pock marked from inside and not keen to fit windows which would cure it 95%
new nsf wing outer
BUT, if I do all that I will need to paint the whole truck - though would be in the original colour.
Should I do it Question
If so, any idea of a budget cost for parts, fitting and painting nicely and who should do it?
It would add value and likely not all the cost, but that isn't the issue. I am more worried about using it less (like my Puma!) when it's all beautiful . . . . . . . . . . Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #651345 19th Sep 2017 6:21pm
Retroanaconda
You're into personal opinion territory really, however my thoughts are that if you've got a 'posh' one to use when you're feeling so inclined then I wouldn't bother.
A Land Rover that is used properly for carrying, towing, travelling etc. will get dents and bumps and so long as panels aren't destroyed or big holes appear they don't detract from the appearance.
Post #651363 19th Sep 2017 7:33pm
Coatesyyy
I reckon it looks cool mate, like a proper work hard 90 should!
Post #651523 20th Sep 2017 3:09pm
okennedy
Ireland
If keeping it original, then the small dings/dents are what makes it an 'honest' vehicle IMHO. But as stated it's up to you... Very Happy
Post #651758 21st Sep 2017 12:10pm
Procta
no harm in giving it a little tidy up even though its a works one, They all do need loving, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #651959 21st Sep 2017 11:53pm
Profyaffle
It does look lovely now.. It's one of those dilemmas, you know once you start on one thing it will lead to another and another..........
I'm a bit precious about Alan but it doesn't stop me putting sacks of stinky manure, filthy wet dogs in the back, lengths of scaffolding boards on the roof or going for the logs with the trailer.. So I say go for it.. Thumbs Up 1993 200Tdi Defender 90
Post #652003 22nd Sep 2017 8:54am
CarMan
Alan was actually one of the inspirations as he is Arles/Windjammer 👍🏻 Rob
Post #652132 22nd Sep 2017 6:14pm
CarMan
Bit of an update after my beloved has been away for about a month with a great local LR specialist who is also a really good friend:
Head gasket started chuffing at the rear so head skimmed and gasket replaced.
New head bolts, rocker gasket & valve stem seals.
Cam belt, tensioners and seals replaced as no idea when last done
Replaced alternator and water pump belts
New rear prop & water pump
Full service including all new glow plugs
Replaced front wheel bearings and seal
Mantec swingaway fitted
Replace front bumper with HD version from Dixon
Lovely to have a him home again and drives all the better for it
Thumbs Up Rob
Post #735083 16th Oct 2018 6:00pm
under_rover
2002 Defender 110 Td5 SW Oslo Blue
There's always something to tinker with Thumbs Up Cheers
Laurie
90 rebuild thread - https://www.defender2.net/forum/topic62909.html
Post #735088 16th Oct 2018 6:10pm
Page 4 of 4 <1234
