Home > Technical > Flickering Fog Lamp
AdamGT3
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Corris Grey
Flickering Fog Lamp
Hi All
I had a day yesterday and replaced the headlamp switch, indicator stalk and fog amp switch in the 2.4 Puma.
I replaced the fog lamp switch as the fog lamp, indicator on the fog lamp switch and the indicator in the dash would flash, very annoying for me and anyone following as this would happen whenever the headlights were on.
Unfortunately replacing the switch did not work and still have the same problems. Are there any common issues that would cause this?
Thanks
Adam
Post #651439 20th Sep 2017 9:03am
dorsetsmith
check earthing
Post #651448 20th Sep 2017 9:18am
Poor earth or maybe a badly seated bulb? Darren
Post #651449 20th Sep 2017 9:19am
AdamGT3
OK Thanks will check bulb first. Where are the earths that would affect this?
Post #651451 20th Sep 2017 9:24am
dorsetsmith
You have two earth header common to both head lamps and fog lamp on 07 > defender K109 down under your dash RH side and in engine bay K108 behind coolant tank
Post #651459 20th Sep 2017 9:58am
Dieselhead
Not the fog lamp control unit its self is it? Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #651630 20th Sep 2017 8:53pm
