Home > Td5 > Intermittent Flat Spot
Page 2 of 2 <12
roel
I sooked a few filter but never as bad as that. Not even after doing this:
 Roel
2003 90 Td5 (2009-now)
Post #650080 13th Sep 2017 2:04pm
roel
lightning wrote:
My 2005 TD5 110 reverts to the low range throttle map if you floor the throttle. It's done it since l bought it in 2014, 36,000 miles ago.
Our 2006 90 TD5 did it from new for eight years and 44,000 miles. No solution was ever found.
On my 110 l have to take care not to press the throttle pedal right down, or l will spend the rest of the journey in the low range map.
lt still drives OK but you have to press the pedal further before the turbo comes in, and then it's more progressive in the power delivery.
Turning the ignition off then back on will reset it. Obviously not possible while driving.
£20 via paypal to anybody who suggests a solution which works (you'll have to trust my honesty with that)
Did you check your throttle position sensor? If the 3 tracks don't correspond you can get weird issues. My guess would be that there is a problem at full throttle position and the ecu will go to a different fuel map. Roel
Post #650082 13th Sep 2017 2:08pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
gazman wrote:
Shocked Shocked Where is your air intake? I don't have any drains on mine as they are all sealed for wading bit mine has never looked like that!
The air intake is the standard wing-side grille. However, I've now discovered that the dump valve rubber teat is missing so it will also have been sucking air/water in via the bottom of the T piece where the dump valve should be located.
Post #650089 13th Sep 2017 2:35pm
dorsetsmith
ESR3162
Post #650101 13th Sep 2017 3:42pm
Intercept
It has the ESR3162 which has some gauze/membrane over its bottom drain port, but it doesn't have an NRC8955. Shouldn't the NRC8955 rubber teat be attached to the bottom drain port of the ESR3162? I don't see it in the diagram Confused
Post #650105 13th Sep 2017 3:58pm
dorsetsmith
NRC8955 is for bottom air box drain
Post #650126 13th Sep 2017 5:44pm
jonny2tanx
United Kingdom 2005 Defender 110 Td5 XS CSW Alveston Red
Intercept wrote:
Problem not yet solved but I'm suspecting a drenched air filter was probably the root cause. I'm wondering if the dump valve isn't working properly - can it be removed for checking?
Wow. That is far worse than mine was. No wonder it wasn't running right. Shocked
Post #650152 13th Sep 2017 7:59pm
lightning
It's a possibility, l'll see how much a new one is.
Post #652442 24th Sep 2017 5:44pm
Page 2 of 2 <12
