Home > Puma (Tdci) > P037D29 Glow plug relay sensor fault code help!!
M94PUMA
Hi chaps,
So plugged my diagnostics reader in last night just for a check and found fault code P037D29 Glow plug relay sensor circuit - signal invalid.
Can anybody help me with this one?
I've checked all the fuses they are ok, the relay clicks when you turn ignition on, glow plug light comes on and then goes out like it should do and cold starts perfectly.
Looked under the bonnet and can't see and loose connections.
Where can I go from here? New relay? Glow plugs?
Thanks
Post #648945 8th Sep 2017 8:39am
A quick search for the fault code revealed the following thread that may help. The circumstances were different (the OP was in Mongolia Shocked ) but it suggest that one or more duff glow plugs may be the problem.
http://www.defender2.net/forum/post291043.html Darren
Post #648952 8th Sep 2017 9:04am
dorsetsmith
may help
https://www.google.co.uk/search?client=fir...-at_EBS2M:
Post #648967 8th Sep 2017 10:07am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Check to see what or if there is voltage at the plugs,
Then remove to visually check they are working. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #648968 8th Sep 2017 10:16am
M94PUMA
So I've just fitted 4 new plugs and the fault code still won't clear, I've now ordered a new glow plug relay, main relay, and starter relay,
Shall keep you updated,
Post #649958 12th Sep 2017 9:11pm
Check for any broken or chafed wires too. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #649960 12th Sep 2017 9:21pm
dorsetsmith
P037D29 Glow plug relay sensor circuit.
the glow plug relay is control by ECM witch use engine temp and air ambient temp for out side air temp
1. ECM has feed back from Glow plug relay check fuse 38 10 amp !
2 . Check sensor circuit for engine temp and air ambient temp
Post #650014 13th Sep 2017 8:51am
M94PUMA
So I had no Fuse 39 fitted and my fuse 38 was a 5 amp not 10, have corrected it now,
See what happens!
Post #650263 14th Sep 2017 12:23pm
M94PUMA
Fuse 39 fitted and problem solved 🙈🙈🙈🙈
Post #650270 14th Sep 2017 12:53pm
dorsetsmith
That's interesting fuse 39 is power supply to the MAF/IAF Sensor Exclamation sheet 4 (B )
Post #650275 14th Sep 2017 1:17pm
M94PUMA
Fuse 39 is still connected to the glow plug system looking at the diagram?
Post #650284 14th Sep 2017 2:24pm
dorsetsmith
fuse 39 reserve power when main relay is closed, main relay also supply + to the glow plug relay coil and ECM provides - to control relay coil
Post #650287 14th Sep 2017 2:34pm
M94PUMA
Update: problem is the 60amp fuse blowing soon as ignition switches on. Where shall I start looking for shorts? All new plugs, link cable is in good condition, all new relays, can't see any exposed cable anywhere, arghhh help please 🙈😭
Post #651119 18th Sep 2017 8:42pm
dorsetsmith
Check for any chafed wires too.
AS custom90steve ^ check dash wiring loom and also check down to the driver seat box too
Post #651199 19th Sep 2017 6:37am
