![]() | Home > In Car Electronics > USB Socket Search |
| greenlandrover Member Since: 09 Jul 2017 Location: Stourbridge Posts: 145
Been doing some experimenting and came up with this: -
| ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2964
Well done that man
Finally got around to installing the USB charger
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Still need to install one on the passenger side too. |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698
Did you try the small 8 digit part numbers (00414040 / 003323033) visible below the engineering number? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Yes I started with one of those sockets. Basically took off the spring lid and opened it up by hand using a step cutter bit until it fitted the Blue Sea USB charger. Then removed the existing cigar lighter and filed hole, again to suit the USB charger. Removed contacts from existing plug (i.e. cut plastic housing off) and put some heat shrink over them to prevent shorts. I think the positive is purple/brown. Ground is black. Mine is an 07MY so it may be different on yours. I put an ‘O’ ring either side of the panel. On the front it fills up the recess in the panel. The one on the back acts as a sort of spring washer. Let me know if you need any ‘O’ rings. I’ve got a box full and I’ll never use all of them!!! Cheers, Jason Last edited by greenlandrover on 7th Nov 2017 5:06pm. Edited 2 times in total |
Martin,
I got them from a site in Germany I think. I’ll have a look when I get home and pm you a link Cheers, Jason |
| rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 945
[url]http://www.baas-parts.de/produkte/steckdosensysteme/za22-Zigarettensteckdose/#prettyPhoto
If that’s the one, there’s a uk source of the same part:- [/url]http://www.conrad-electronic.co.uk/ce/en/product/1289381?insert=EG&awc=5769_1510082526_979e87dfebc0ee817807fb01dee97fad&utm_source=affiliate_aw&utm_medium=global_aw&utm_campaign=global&utm_banner=global&WT.mc=affiliate_aw_global |
Just found this...
http://www.conrad-electronic.co.uk/ce/en/p...K?ref=list Click image to enlarge |
That’s nice!
Another thing I’ve thought about for the passenger side is hiding the charger itself behind the dash and then run a USB cable to one of these: - Click image to enlarge http://www.neutrik.com/en/multimedia/usb/nausb-w-b With one of these to keep the dust out: - Click image to enlarge http://www.neutrik.com/en/multimedia/multi...ies/sccd-w |
| nihwrd Member Since: 12 Apr 2012 Location: Somerset Posts: 28 |
Hi all
I've recently upgraded to a Double Din fascia and didn't remove the cigar lighter from the old one as I thought I'd replace it with a USB connector instead. My H/U has 2 USB inputs (one for ApplePlay) but the second supports iPod or other device, so I'm after a USB connector rather than a charger. Any views on what is the best option (to fit in the existing lighter hole)? Nick |
My post above yours is just a connector so you could use that
Hi GL
I note that the one in your post has a square end - is this removable or does it sit inside the fascia? Nick |
| Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587
The rectangular surround of the Neutrik connectors can sit on either side of the mounting panel. http://www.neutrik.com/en/multimedia/multimedia-connectors/usb/ Full engineering drawings are available on each product page.
All
Just ordered one of these: https://www.amazon.co.uk/XTRONS%C2%AE-Dash...B00VWO746G as my H/U has both Aux and USB in. Will fit it this weekend and report back Nick |
