![]() | Home > In Car Electronics > Installing BBUS into TD5 |
I don't think you even need to enable it, just bolt it in and plug it in. Td5 should have the correct harness for a standard installation unlike the Tdci which doesn't.
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 ![]() ![]() ![]() |
Sorry for asking, but what is a BBUS?
Greetings, Joris |
Battery Back Up System for the alarm. Darren
I see, thank you!
Joris |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 727 ![]() ![]() ![]() |
Thank you Blackwolf, I'll have a go later on. Once fitted is there a way to test that its working? Looking at the wiring it seems that unplugging it will cause it to sound? 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
Two tests are worthwhile:
1. Open the drivers window, then lock the car with the fob and wait for the alarm to arm. Then reach in and unlokc and open the door, the alarm shoudl sound and the BBUS should be heard. 2. Disconnect the battery (but allow several minutes after stopping the engine before you do so to make sure that the alarm is armed), the BBUS should sound. |
Fab, thank you for the quick response
![]() 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
