![]() | Home > Td5 > Turbo actuator pipe |
about 5mm i would say. i do not have a pipe going to the air box. does your td5 have a turbo actuator solenoid?
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6035 ![]() ![]() ![]() |
Sorry, my bad, Not to the airbox but to the pipe from the airbox.
I will get a picture later. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2232 ![]() ![]() ![]() |
Defenders dont have a modulator. The pipe diameter from the actuator to hot pipe is 4mm.
If the EGR is blanked the airbox pipe is void. |
This pipe circled - goes from turbo actuator to the lower intercooler pipe
![]() Click image to enlarge 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
4mm
cheers 1999 Defender TD5 110
Ordered a length of 4mm ID pipe. A whopping £1.79 1999 Defender TD5 110
4mm did the job - cheers 1999 Defender TD5 110
