Home > Td5 > Wiper problems.
kweese
Canada 1999 Defender 110 Td5 SW Belize Green
Wiper problems.
Greetings.
I have an issue with my front wipers. They do not go back to the normal seating position if I turn it to the off position. It will stop a half second or so after I turn it off and it will stay where it is instead of going back down to the lower windshield position. What can be wrong? I was thinking the relay. If so, should I upgrade it to the one that people suggest from a VW? What is that part number? I'm in Canada, is there a part number from another vehicle that I can use that is sold in Canada,? Thanks again
Post #649214 9th Sep 2017 10:17pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Wiper motor park switch has packed up. Can be replaced fairly easily. This thread explains all! Thumbs Up
defender2.net/forum/topic2031.html?highlight=wiper+park+switch Just because you're offended doesn't mean you're right.
Post #649220 9th Sep 2017 10:37pm
shropshiredefender
Post #649221 9th Sep 2017 10:40pm
I have the ideal solution:
http://www.bbc.co.uk/news/uk-england-birmingham-41212203
Whistle Rolling with laughter Rolling with laughter ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #649222 9th Sep 2017 10:42pm
shropshiredefender
Steve
You've found a dealer fitted option for the new Defender! Rolling with laughter
Post #649313 10th Sep 2017 12:46pm
kweese
Is there a park switch on both motors? also, my defender is LHD.
Post #649502 11th Sep 2017 1:48am
There's only one motor for the front wipers. On a LHD vehicle, it's located behind the RH end of the dash. It drives both wipers via a flexible spiral drive rack. The park switch will be the same regardless of which side the motor is mounted. Darren
Post #649518 11th Sep 2017 8:12am
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Since you're opening the dash, you might as well replace the cable at the same time. Ours recently broke at 135k km, 20 miles from the harbour where we would board the ship to Iceland, so we had to source parts there. Unfortunately I forgot that I had a park switch with me and of course, that started to show wear 2k later.
Joris
Post #649539 11th Sep 2017 10:45am
